different cranksahft pulley bolt options for A series
Am I the only person fella that finds the socket for the A series crank bolts too large?
Is there a smaller option available like a 17 or 19mm?
Ive changed a few seals that needed this monster socket but usually at a friends workshop
but would love to have a 19mm instead even my suzuki 1.6L takes a cheap wonderful 17mm.
Posted on: 2012/10/25 0:18
Re: different cranksahft pulley bolt options for A series
From Sydney
Cant remember the thread size on the crank pulley bolt. its either 14mm or 16mm. Bolts suppliers will have options, even a sucket head cap screw if you want to go down that road. 8.8 high tensile at a mimimun should be used.
OK found it, 16 x 1.5 pitch. you may need one of these as well. •12308-H1000 WASHER-PULLEY BOLT
Posted on: 2012/10/25 1:48
Edited by benny on 2012/10/25 2:28:38
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
That is very helpful Benny!
The stock A-series crankshaft pulley bolt is:
Stock Part Number: 12309-78200 ($4.58)
M16 x 1.50 (fine) pitch
15mm diameter
27mm long
The head is 27mm hex and about 15 mm thick.
Torque: 15-16 kg/m (108-116 ft. lb.)
Posted on: 2012/10/25 2:05
From Malaysia
yeah a little bit too big. because L series use same 27mm.
Posted on: 2012/10/25 2:24
Its sure to spins faster with a smaller head :)
Posted on: 2012/10/25 2:39
Is the length right 27mm long?
Posted on: 2012/10/25 4:03
Crank pulley bolt on my A12 measures at 27mm long
Posted on: 2012/10/25 4:33
Thanks DD so the head is 27mm and so is the length of the threaded section? - Ive just rang a bolt and fastener joint and they only have 50mm thread length definitely dont want to cut it but then they only have 23mm hex head which is far from 19mm :{
Posted on: 2012/10/25 5:01
From Sydney
General rule of thumb: As long as the thread engagement of the bolt into the crank = the diameter of the bolt, as a minimum [1.5 X bolt dia is better], you should be OK.
Posted on: 2012/10/25 5:02
1970 KB10 Coupe
S13 caliper b...
From Freo
D, just go and fetch a cheap socket....
Posted on: 2012/10/25 5:18
A15 PSI Project Motor
'72 CB750k,
