Can you identify these......
Not too shy to talk
From SOUTH AFRICA
Hi Guys,
took the head off my supposedly stock (never been touched before) A15 and found these pistons inside, apart from no 4 that probably had a chew down on a broken piece of a valve, there is no damage to the head.
these pistons are not standard ones, can anyone perhaps identify them, mainly because id like to find out if its worthwhile machining them dowm to drop CR for turbo ?
jpg  A15 pistons.JPG (114.40 KB)
6385_508e3abb53e89.jpg 640X480 px
Posted on: 2012/10/29 8:14
Re: Can you identify these......
That looks standard to me. There are varying types of dished pistons and these are one of them.
Posted on: 2012/10/29 8:22
I would be cautious in machining these down. Why don't you go for a bigger dished piston, thick head gasket or bigger cc cylinder head combustion chamber? H75?
Posted on: 2012/10/29 8:25
From Sydney, NSW
I just rebuilt my A15 (stock) and these are the same pistons that were in mine, pretty sure they are stock ones bro...
Posted on: 2012/10/29 8:31
Daily: 2000 Holden VX Calais 5.7L GenIII
Datto: 1972 Datsun 1600 L20B twin 40 DCOE Webers
Not too shy to talk
From SOUTH AFRICA
Probably then an imported engine, because the local(south african version) of these pistons looks a little different.
Maybe just go with new pistons, like you said.
thanks
jpg  images (1).jpg (5.09 KB)
6385_508e3f34c25db.jpg 259X194 px
Posted on: 2012/10/29 8:33
Not too shy to talk
From SOUTH AFRICA
learning everyday !!!
Thanks guys!
Posted on: 2012/10/29 8:36
From sydney.nsw
1st pic are a15 std type pistons.
your last pic seem to look like a14 pistons'
different comp hieght; a15 30mm c/h
a14 32.5mm c/h
Posted on: 2012/10/29 8:38
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From Townsville, Qld
Strike three for original pistons, my unbored A15 has them. Stupid really they could of saved some coin by using standard style dishes in thier A15 pistons
Posted on: 2012/10/29 8:39
That dish is pretty good already for light to moderate boost.
That second dished piston is the broad shallow dish that I tend to find in A14 engines, except the EGI model, which has similar dish to the one you posted earlier.
Posted on: 2012/10/29 8:40
Not too shy to talk
From SOUTH AFRICA
Thanks Bige, I'll keep that in mind.
