« 1 2 (3) 4 »
Re: top speed out of a fair stock a12
Quite a regular
From cootamundra.. NSW
ive had my ute up to approx 190. the clock goes to 165 and it wound right off and still wanted to keep going. its powered by an a14 with twin su carbies, 2 inch exhaust and a 5-speed a-series gearbox.
Posted on: 2004/4/15 7:11
From Toowoomba QLD
My ute is good for 160 and it is still stock, mind you thats ringing its neck. And you get some strange looks from falcons etc that are doing 130-140 and you go around them. It's what I call the WOW factor.
Posted on: 2004/4/15 7:24
From Perth W.A
I got 155-160 out of my A12 with auto and i wound it off the clock with my A14 with 4spd and i guestimated it being about 175kmh
Posted on: 2004/4/15 7:30
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From Brisbane
Got my old stock a12 to (12 inch rims) 140kph...
wasnt game enough to go any further didnt exactly feel real safe not in stock form anyway
Posted on: 2004/4/15 7:33
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From SA the place to boost
i had my old 1200 sedan with A14 cam extractors/exhaust carby off the clock right down in the dash so i couldn't even the needle in 4th gear at about 7200rpm. i probably wouldn't do it again becoz i have grown up since then (i think)
Posted on: 2004/4/15 9:09
From Christchurch NZ
My old 1200 coupe could do 6000 rpms in forth. One day I held it there for a long time indeed. Later on the same trip , I went down a long downhill straight I had the needle pointing straight down. It was valve bouncing its nuts off.
Posted on: 2004/4/15 9:16
Forced Induction!
From hobart,tas,australia
the thrashability and simplicity of the aseries is what makes it fun
Posted on: 2004/4/15 10:48
From Melbourne, Australia
i heard of a guy once....
he had an a15 back round to just before it hits the stop pin at 0, and this was just down a main street between intersections, but inaccuricies in his speedo would suggest this was about 180km/h
apparently he has turbo now so maybe he can bend the needle around the stop pin
Posted on: 2004/4/15 14:28
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Not too shy to talk
From Newcastle, NSW
ive done blinker speed in mine
i had the nedle on the bar graph type speedo in my 1200 sedan pointing at the right hand blinker. one morning on the way to tafe. On the pacific highway around catrine hil bay for anyone around the newcastle- central coast area
Posted on: 2004/4/15 14:44
From Palmie, New Zealand
A question. Would larger rims put out your speedo by it reporting a greater speed than actual? and also, what does a pretty much stock A15 in a 1200 get up to with a 4speed? and how much more would you get out of an A12 with a sunny 5speed (i know its been discussed many a time before)
Posted on: 2004/8/31 6:15
« 1 2 (3) 4 »
