Need Advice on Spacers for +38 offset..
From Leeton NSW
Hi guys im after a pair of 15mm-20mm spacers for the front of my 1200 ute as im have trouble with the rim +38 offset hitting the strut which means i cant even get the rim on properly..as you can see the top stud isnt all the way in properly and its on angle and the other pic is of the rim hitting the strut.Also i was just wondering if i was to put on say 15mm spacers would i need to change the wheel studs to longer ones??
jpg  643944_10151171134923521_1403110927_n.jpg (135.30 KB)
16008_5091f51623c9a.jpg 960X720 px
jpg  154197_10151171134543521_2014852234_n.jpg (57.88 KB)
16008_5091f51f114f3.jpg 720X960 px
Posted on: 2012/11/1 4:07
Edited by violi on 2012/11/1 10:23:07
Edited by violi on 2012/11/1 10:58:34
Re: After a pair of 15mm-20mm spacers..
Yes, longer studs.
Stock are M12 x 1.25 32mm long. Knurl Diameter: 13.00mm
Longer 55 mm versions (which are really long)
* NISMO 40222-A0220 [2" long/51mm]
* For B110 front, 510 front
* Knurl Diameter: 12.90mm
These match the NISMO but are shorter:
length 45.5mm
* 40222-15C01 GC22 Van $2.12 USD each
Posted on: 2012/11/1 5:49
eBay buy bolt on spacers, there's a company that makes 3piece sets so you can change the thickness the company's like G something
Posted on: 2012/11/1 5:51
Car free
Are spacers illegal? Couldnt you just make a set or have some made by a local metal work shop or something, surely cant be that much...
Posted on: 2012/11/1 6:04
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
From A-TOWN
Autobarn sells em, wouldn't hurt to run longer studs
Posted on: 2012/11/1 6:15
From Brisbane
GKTech is what your thinking of supafatto
Posted on: 2012/11/1 6:45
From Leeton NSW
ok i found 2 sets on ebay ill post the links my rims are +38 offset and dont fit by a decent amount roughly what offset will i need to fit them on the front im thinking a 20mm spacer as i was told i need to get it down to like +6 to +20 but can only find 15mm spacers or 25mm spacers in Australia..Also i need to know the bore size of the hub so i can see if they will fit as the spacers im looking at buying are 67.1 mm..the links-
http://www.ebay.com.au/itm/4x114-3-4- ... ae3&_uhb=1#ht_2722wt_1007
http://www.ebay.com.au/itm/1509253676 ... m1423.l2649#ht_2668wt_783
Which ones do yous reckon??
Posted on: 2012/11/1 10:22
Re: Need Advice on Spacers for +38 offset..
will they fit inside the guards?
Posted on: 2012/11/1 10:34
1200 Ute - Mild A12
Now that you have the wheels, you can fit some washers on the studs as spacers and see which thickness looks best (rather than the previous estimates).
From Leeton NSW
yehh im not sure..I was just thinking that ddgonzal its the only way i will figure out what size i will needhaha thats a weekend job im busy studying for HSC at the moment haha
Thanks
Posted on: 2012/11/1 10:51
