Max hp from CA18det
From Goulburn NSW
Hi guys what sort off hp can be achieved from a ca,max
Posted on: 2012/11/9 5:58
Re: Max hp from CA18det
650 HP
Posted on: 2012/11/9 6:10
Oh I was wrong.
It's over 700 HP.
Posted on: 2012/11/9 6:18
Sorry but depends how much you want to spend.
Stock internals easy 250kw but in a 1200 good luck getting power to the ground. Its all the supporting mods like brakes and diff etc you need too.
Posted on: 2012/11/9 7:57
Tomei Stroker in Japan over 800hp - ca20det
Why would u want max hp when its better to have usable hp?
200-240hp ATW is more than plenty in a 1200 especially
if its got response in any gear whilst big turbo high boost
setups are not really street friendly unless you go for
compounded turbos but big $$$ to sort out in one go.
Posted on: 2012/11/9 8:33
From Melbourne,Australia
Ive got a zoom mag with the yatalla headworx 1200 sedan the ca in that makes 700hp at the tyres with a gt42 turbo. Doesnt come on boost till 6000 rpm but
Posted on: 2012/11/9 9:03
From Brisbane
i seen around 700hp... the bores start to crack above that tho(45psi), block needs to be sleeved max horsepower could be as high as 900hp if someone did a all out build. hoping to make 550hp with my ca setup.
Posted on: 2012/11/9 9:07
From Christchurch NZ
A mate of mine (who has a pretty wild forged CA18det in a 510) is friends with that Yatala headworx guy on the book of faces. Apparently hes up around 760hp now. (Or thereabouts, I was probably otp when the guy was telling me bout it)
Posted on: 2012/11/9 9:38
Forced Induction!
From Brisbane
i remember reading he even got to 814hp. Not sure what happened to the engine.
Posted on: 2012/11/9 9:55
maybe a question just as important - how long do you need it to hold together for?
A motor that survives a year of monthly drag race meets, probably wouldn't survive a season of circuit racing, and a motor that holds up to circuit racing won't likely hold up for a season in a speedway environment.
Posted on: 2012/11/9 9:59
John McKenzie
