Brake Light Problem
From Brisbane
car is sunny a12 round headlights
the car have 4 lights (red tailights)
the problem is when you turn the headlights on these 4 lights light up but the inner lights are dimmer than the outside light (all lights should have the same brightness) THEN when you press the brake pedal RHS brake lights go off, LHS works OK.
When the headlights are OFF brake lights work but RHS is dimmer than LHS
Any ideas?
RHS = Right Hand Side
LHS = Left Hand Side
Posted on: 2004/4/20 3:54
Re: Brake Light Problem
From Auckland, New Zealand
Hmm.. i think i get what your saying..
I initially thought bad contact i.e earth points around cluster of light or at contact of the brake pedal switch - causiing a varying/fluctuating amounts of current to go to the bulbs - perhaps?
You could also check that both of the filament wires are intact in the bulbs.
Sounds pretty basic and you may have done all this stuff already - but give it a go if you haven't, might get lucky.
Posted on: 2004/4/20 5:59
#Datopower#
I take it this only happens when you are on high beam and not low beam??
Posted on: 2004/4/20 6:24
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
From Canberra, Australia
This will sound stupid,
But does the horn work?
My brake lights were doing funky things.
Was the fuse, same fuse for horn and brake lights.
Otherwise, I agree with it being the earth...
Or perhaps a alternator/battery issue?
Posted on: 2004/4/20 6:53
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From Castro Valley,CA USA
I've had a similar problem on my wife's old car. When you hit the brakes, some lights get bright, others turn off. After a few weeks, the bulbs would burn out.
I would check and double check to make sure you have the correct bulbs installed. Then check the ground wires to each tail light assembly.
As it turned out, my wifes car had a loose ground wire on one side.
Posted on: 2004/4/20 7:23
From Toowoomba QLD
sounds like a loose earth wire somewhere, and as you are having more trouble with one side than the other, I'd look there first.
Posted on: 2004/4/20 7:29
From Brisbane
the problems occurs on low and high beams
and horn is working
checked the bulbs filaments and they are perfect just bought these 3 weeks ago
checked the fuses as well
I'll check the earth.ground wires again...
Posted on: 2004/4/20 21:35
Not too shy to talk
From Madeira-Portugal-Europe
hello.try to check the wires atach to the headlighs.the problem is the ground wire is not making a good contac or the lamps is not making good ground contac.
(sorry my english ,i am portuguese and not very offen spech or rite in english)
Posted on: 2004/4/20 22:41
From Brisbane
Hey its your 1st post!
Welcome
thanks for the reply will check later
Posted on: 2004/4/20 22:46
Not too shy to talk
tanks. in fact is the 1
Posted on: 2004/4/20 22:53
