« 1 (2) 3 »
Re: a series 5 speed
From Adelaide, SA
Ok fellas - while we're on this subject, in the tech section it says this:
RS5W60A (Vanette) can be used for parts
What exactly does it mean by 'can be used for parts'? Will it not go into a 1200?
TC
Posted on: 2004/4/21 9:48
Quite a regular
From cootamundra.. NSW
ive had the a-series running behind my a14, havent had any troubles, does 3000rpm at 100kp/h and 6 litres of fuel per 100 km. i thinks thats pretty good ey
From Brisbane Australia
I read that as column shift as opposed to floor change
Posted on: 2004/4/21 9:55
From Adelaide, SA
Of course - probably is column shift...
Maybe I can do conversions to the uterus...NOT!!!
Posted on: 2004/4/21 11:51
From Millgrove Vic OZ
American B210 and some JDM 210's with A15 I believe.
Ratios are 3.382, 2.013, 1.312, 1, 0.854
Posted on: 2004/4/21 12:42
Cheers Feral
From Sydney, Australia
The Column Shift was available as an option on the 1200...only for the Auto though..
Posted on: 2004/4/21 12:47
From Auckland N.Z
i had a look at some vanettes at pic-a-part last weekend and they are quite different because of the coloum shift and it didnt look like you could just change it to a floor shifter. otherwise i emagine everything else is the same.
Posted on: 2004/4/21 13:00
From T'ville
we had a look at the colum shift boxes briefly and thought that a front wheel drive shifter mechanism and cables could be used to select gears, but never put any time into development,, anyone interested
Posted on: 2004/4/21 13:54
Pitroad sells the back extension housing & stuff to convert 5-speed column shift to floor shift.
Posted on: 2004/4/21 16:46
Ade, the 60L and 60A are both for A-series engine. Your transmission sounds like a winner, I wonder what vehicle it orginally came in? Maybe it was a competition part?
If you can get the serial number stamped on the top of the bellhousing flange area, post it here, and I'll add the info to the 5-speed article.
Posted on: 2004/4/21 16:48
« 1 (2) 3 »
