« 1 (2) 3 4 5 6 »
Re: rear discs on h165 or h190
From Sydney , NSW
A 6mm (or 8, not sure) flat plate appropriately shaped will fit R31 discs and calipers. Bolt the plate to the inside of the end flange using 2 longer bolts. Think I have a template floating about somewhere.
Cheers.
Posted on: 2013/1/6 6:38
All torque, no traction
A division of "My mate's ....." engineering
From Adelaide
If your axles are the same length you could try swapping left to right? I just did this on mine that's sitting on the floor and it moves the calipers to the back just above the spring perch.
The downside is having to work something new out for the handbrake cable which is now sitting in a funny spot. Might make what you have workable though.
jpg  diff-reverse axles.jpg (168.22 KB)
11744_50e93d152fb25.jpg 418X416 px
Posted on: 2013/1/6 8:42
Edited by lamb_daiquiri on 2013/1/6 9:00:16
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Melbourne, Australia
that is a great idea i hadn't worked out, but the same problem as if i flip the backing plates 180... that handbrake cable...hmmm
i wonder how hard it would be to adapt some flexible handbrake lines to work with that (which is essentially what the r31 brakes gives me)... might have to head to pick a part and see how they hook up
Posted on: 2013/1/6 9:46
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Adelaide
I was looking at it thinking some pulleys attached to the right spots might do the job. I reckon you can figure something out for the handbrake.
Posted on: 2013/1/6 9:58
From Christchurch NZ
I'll try find a pic of my set up.
I've got limited time online atm.
Posted on: 2013/1/7 7:03
Forced Induction!
Here's a pic of the one my mate did. his thread shows both versions of the caliper plates.
http://www.nzdatsun.com/forums/viewtopic.php?f=9&t=15&start=10
Login maybe required to veiw, but it only takes a couple in mins to register.
Posted on: 2013/1/7 7:14
Forced Induction!
From Adelaide
I've had a couple of ideas about the hand brake. One is to weld another arm on the other side of the leaver and set the cable up to pull it toward the aluminium backing plate. I see this working by using a cased cable with the free end fixed to the backing plate. With enough free lengh the casing should pull toward the backing plate. SO far that's the simplest idea I've had.
Something else I'm wondering is if there's any other calipers that would fit that have the handbrake mechanism built in, like these:
jpg  Handbrake caliper.jpg (29.42 KB)
11744_50ee7e2000d21.jpg 549X387 px
Posted on: 2013/1/10 8:39
From Adelaide
By my measurement the bolt spacing on the rear calipers is 97mm.
Posted on: 2013/1/10 9:32
From Adelaide
As a side note, the caliper slide seals off the VT rear calipers I have fit onto the bluebird calipers. Good news since the bluebird slide seals are shot. Apparently PBR and Girlock share this part.
Posted on: 2013/1/10 11:03
U13 bluey have an intergrated handbrake lever.
Posted on: 2013/1/11 9:35
Forced Induction!
« 1 (2) 3 4 5 6 »
