« 1 2 3 (4) 5 6 »
Re: rear discs on h165 or h190
Won't it make it worse as lifting brake nipples closer to the chassis rail/body?
Posted on: 2013/1/16 12:29
From Adelaide
With the brakes in the position I have them now the handbrake lever hangs down about 80mm and should just clear the springs/ brakets. I don't think it would fit around lowering blocks. With the hand brake lever pointing back it would be the same as without the blocks, just the diff's always closer to the body like anfam says.
(Those are nice looking braided lines Benny) Shiney.
Posted on: 2013/1/16 20:20
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Melbourne, Australia
True, my simplest solution is to just remove the lowering blocks I have.... But I am not willing to run it high just to clear brakes
Posted on: 2013/1/16 20:52
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Adelaide
If you want to pull the whole assembly apart and drill some new holes you could place the brakes how I have them but pull the handbrake assembly out of the drum and flip that as well. That might put it in the right spot. I guess if it's too much stuffing around it might be easier to get different brakes.
Posted on: 2013/1/16 21:35
Can you get shorter bleed nipples off other type of brakes? It's only a bolt with a hole in it. Just makes harder to bleed
Posted on: 2013/1/16 22:20
They are hitting in three places at the moment, not just the nipple. I'm liking that idea lamb-daq, might try on spare parts tonight under the house where its cool. Problem is it appears all solutions are a pain in the penis so I may as well use the ones I have if possible
Posted on: 2013/1/16 22:55
1200 Coupe Rallycar
Use the penis or parts you have at the moment
Posted on: 2013/1/16 23:03
From Sydney
Back when I was using the Bluebird rear brake setup, the bleed nipple would tap the chassis rail on certain type corners. I managed to stop it by heating up the chassis rail with some oxy and giving it a slight massage to get an extra 5mm or so clearance.
Posted on: 2013/1/16 23:51
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
I had a good play around today.... None of the re-arrange ideas will work
Posted on: 2013/1/17 11:03
1200 Coupe Rallycar
Once again was that with the tool or the parts rc?
Might have to massage like Benny said for your happy ending
Posted on: 2013/1/17 11:10
« 1 2 3 (4) 5 6 »
