Feedback on reverse eye leaf for ute...
From NSW
Hi all, has anyone bought the reverse eye leaf springs and the adjustable koni shocks from maddat?? if so how did you find the setup?? (going into 1200 ute)
Posted on: 2013/2/4 0:13
Re: Feedback on reverse eye leaf for ute...
I'm running the same set of Konis in the rear of my ute, and I'd say compared to the KYB shocks I had, they're much better. More so over corregation and small bumps like that they're much more sturdy and a little softer...
I can't say much about the leave springs but surely you could flip a leaf to get it lower for lessthat $500?...
Posted on: 2013/2/4 0:32
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
The Maddat leafs are for more than just flipped leafs. They are a combination lowering spring and traction spring:
* Flipped half-leaf to control torque windup
* Reversed eyes for lowering
* King Springs lowering base
As to how well the work, I still haven't heard a review. Just that Maddat has a reputation of selling good quality parts.
Posted on: 2013/2/4 2:34
From NSW
Bump
Posted on: 2013/2/4 9:23
From Melbourne AUS
would these reverse eye springs foul on the chassis of a ute at the front leaf spring mount?
Posted on: 2013/2/4 9:30
1973 B110 A12
From Western Australia
you are right in thinking that mods are required.
a small piece will need to be cut out of the rear boxed section of the front leaf spring chassis mount.
easy enough to do.
Posted on: 2013/2/4 11:22
1200 Sedan SR17VE + TURBO (Borg Warner twin scroll), 6 Speed, Brembos, Autronic SM4 ...coming together slowly.
Stanza rally car mostly ex works = FIA head, 50mm Mikunis, option one, works diff, 4 pot FIA calipers and vented disc all round, enkies, h...
If your cutting chassis make sure you reinforce that area.
Posted on: 2013/2/4 11:33
