threa size of heater inlet
From Sydney, NSW
hi all I have to tap a thread for my heater in an austin i put an a14 in inlet part number 27070-H1000 CONNECTOR-WATER INLET [rear of cylinder head] $4.13
just wondering if anyone knows the thread size
I have to tap.it at the front of the block as there isnt enough clearnace in the rear.. the engine is mounted too far back.. cheers
tom
Posted on: 2013/2/12 21:34
Re: threa size of heater inlet
I believe it is tapered Pipe Thread.
Does the cylinder head you are using have a threaded connection at the front? You could put the heater hose there.
Also keep in mind that the A-series engine does not require heater hoses. It will run fine with the head plugged.
Posted on: 2013/2/12 22:19
Not too shy to talk
From San Francisco Bay Area, California, USA
ddgonzal, In the first picture you posted can you block off both (top and bottom) of the heater outlet/inlet?
Will it affect the cooling of the block?
What is the best way to plug them? Thanks again!!
Posted on: 2013/2/13 1:20
1972 Datsun B110 Coupe
1992 Honda EG8 (EG9 replica)
1999 Honda EJ6 Hatchback
From Sydney, NSW
Hi DD it does have the front threaded but i was thinking of putting in a water temp gauge..
I wanted to install a heater hence wondering how best to do it given the stock inlet is unforunately unaccessible!
got the dizzy fitted on my a12 I didn't have a timing light handy so the mechanic who was doing my rego said he'd put it in for me.. took it for a drive down the st when he was done and it was spluttering like crazy.. i asked him if he'd even timed the motor.. crazy!
Posted on: 2013/2/13 1:38
You do not need a timing light. Set the timing static, since you know the specifications. It will be every bit as good as with a timing light. To fine-tune it do it by ear, not by the timing light.
Posted on: 2013/2/13 1:58
From Sydney, NSW
so set it initially so the timing mark's around the 7dbtdc and go from there? but make sure the reluctor and rotar line up?
Posted on: 2013/2/13 2:00
The A-series block (unlike certain L-series) does not need any heater hoses.
Yes, plug them. Hundreds of thousands of factory A12 Datsuns came without a heater.
* Back of head: remove fitting and fit plug
* Lower radiator hose: replace with single-piece hose (without heater hose adapter)
You could also just cap the fittings. Or run the long heater hose to the back of the block, bypassing the heater core. Any method works.
See http://datsun1200.com/modules/mediawi ... .php?title=Heater#Removal
Posted on: 2013/2/13 2:01
From Sydney
3/8 bspt. Your could also retap it to 3/8 bspf in order to fit non taper thread fittings /adapters etc. I recently did the later in order to fit a 3/8 bspf/An-10 adapter fitting.
Posted on: 2013/2/13 2:23
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Sydney, NSW
Thanks Benny! just what i needed to know! :)
Posted on: 2013/2/13 2:27
