« 1 2 (3) 4 5 6 ... 11 »
Re: [EOI] - Flex-Form Composite Leaf Springs Group Buy
Could someone with the knowledge kindly fill in the specs for different body types. Ill send a follow up email to mark to find out what the best shipping price is per package and we will confirm an order with him. That is I'm assuming people are still interested in a group buy? Oda70 is the pair your talking about ordering part of this buy?
L18_B110 - with 200-225lb fronts what spring rate would you suggest for the rear on a ute?
Also what do you suggest for a ride height or lowering spec? I don't particularly want mine slammed maybe just over the outside of the tyre.
Posted on: 2013/2/25 5:17
Just for the interest of this buy, Ive yet to measure the specs will sometime this week but although not slammed the mono leaf would be better close to flat with only a slight angle this will make the car low enough the first time and maybe not sure o this but maybe able to raise the height with stronger rear gas shockers as Ive always had issues with non factory replacement rear shock absorbers always raising the rear up way more than desired on previous rides.
Posted on: 2013/2/25 6:27
From Brisbane, Australia
My advice is to talk to some experts and make your own decision. The stiffer the rear spring, the more tendancy the car will have to oversteer. Bear in mind that you can't make a stiff carbon monoleaf softer, but if you find its a bit too soft, you can always add a swaybar to make it stiffer and fine-tune your handling balance.
Posted on: 2013/2/25 8:30
Edited by L18_B110 on 2016/3/31 23:39:16
From Brisbane
ruredi, I can wait and order as group buy.(need my car running by April). I reckon package in groups of two and same city or something. Interesting info L18_b110. I will try and get some more info and ask king springs about they leaf package rate. Mark said he had the info about the spring sizes already. Only two options with height aswell.
Posted on: 2013/2/25 9:37
125 lbs sounds about right as coilovers could also be used for extra adjustments.
Posted on: 2013/2/25 9:42
From Brisbane
ok talked to king spring to get some rate info. Steel leaf pack made for coupe is 30mm lower and rate of 140lb. stock rate he reckons was 110lb. I wonder what maddat set is rated at with reversed eye and how many inchs lower. 150lb maybe the go with ca setup
Posted on: 2013/2/26 3:05
From Brisbane
someone want to ring scott from maddat to get some info?
Posted on: 2013/2/26 3:07
no coilies Brenton?
Posted on: 2013/2/26 3:09
coupe leaf spring is same as sedan - no difference
Sedan,Coupe: 109 lb/in
Van: 137 lb/in (on overrider)
Truck 4-leaf: 149 lb/in (on overrider)
Truck 5-leaf: 203 lb/in (on overrider)
Posted on: 2013/2/26 4:08
From Brisbane
D, adjustable konis on soft. Thanks for more info ddgonzal.
Posted on: 2013/2/26 4:21
