« 1 ... 3 4 5 (6) 7 8 9 ... 11 »
Re: [EOI] - Flex-Form Composite Leaf Springs Group Buy
From Brisbane
Put me down for a set. I can measure the steel leaf 4 pack up on Tuesday to get a idea where the low arch spring will sit. The Ute steel leaf pack is pretty stiff which is 150lb and composite leaf will feel softer at that rate.
Posted on: 2013/3/2 4:05
From Perth
Don't forget to factor in your GST and duty. You won't get away with it without it
Wheres this guy located in US ?
Posted on: 2013/3/2 5:49
From Western Australia
Still in.
Wanting low arch 130-150 lb with offset/reversible front eye for further lowering if needed.
Also keen from tramp control device.
Posted on: 2013/3/2 5:57
1200 Sedan SR17VE + TURBO (Borg Warner twin scroll), 6 Speed, Brembos, Autronic SM4 ...coming together slowly.
Stanza rally car mostly ex works = FIA head, 50mm Mikunis, option one, works diff, 4 pot FIA calipers and vented disc all round, enkies, h...
That's an excellent price. When we asked years ago, it was $400 each in the group buy without shipping.
Posted on: 2013/3/2 6:58
From Brisbane
From what i read in that other 311 site thread. You can glue and bolt your own eye/bracket to get a lower fit if you need. Not sure if mark still does that, would have to ask i guess. Need to also find out if the bushes are different between 1200's. Could check fulcrum website i guess if we dont know.
Posted on: 2013/3/2 8:39
Why don't you check Datsun1200.com? See Leaf Springs, section "Bushings". Front bushes for Ute/Wagon differ from Sedan/Coupe.
Posted on: 2013/3/2 19:34
From Brisbane
did read that but always good to double check i guess.
Posted on: 2013/3/3 1:38
What's actually different about the bushings? It only has pics.
From what I understand, if you reverse the front eye it will foul the mounting bracket and you would have to cut a piece out to make it fit?
If the arc can be customized to suit the height you want, what other reason would you reverse the eye?
Posted on: 2013/3/3 3:15
For those in the know wouldnt it make sense to just get one with the smallest arc?
Ive seen 1000 (my vb10, b10 & someone elses kb10) and 1200 coupe (sykine?) lowered to the point the rear leaf is almost flat yet still has plenty of clearance without looking slammed but quite good.
ATM priority is to get the DeDion tubing made for an alloy diff I have planned, then leaf springs mounting shackles might be made bigger to suit wider spring so holding off on order.
Posted on: 2013/3/3 3:46
From Brisbane
thats the listings for datsun bushings
http://www.superpro.com.au/find-super ... Sedan--Utility/49-106-159
Spring Front Eye Bushing two different size bores
Posted on: 2013/3/3 5:04
