Anybody have a stock A15 manifold?
From Las Vegas USA
I have a track day coming up and my GX head is taking longer than anticipated. I've got a couple of H89 cylinder heads but no manifold (flat slide carb manifold is GX bolt pattern). I do have a weber 32/36 but it's a round port................so anyone have a A15 stock manifold? Preferably in USA
Tom
Posted on: 2013/3/31 21:14
Re: Anybody have a stock A15 manifold?
From Snohomish, WA USA
I'd give you mine but I gave it to DD. Talk with him. Round port with some mild porting and I think I even left the weber carb plate on it.
Posted on: 2013/3/31 21:30
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
I have one but I'm in Sydney
Posted on: 2013/3/31 23:50
datsun a15 ute
From Las Vegas USA
I'd be after a oval port manifold...............the head has water passages. I've been out in the garage and the 2nd H89 head that's tapped for the stud position I need. Worst case I could use that with the flat slides and then just re-jet.............rather not though.
What's the travel time for a package from Sidney to Vegas??
Tom
Posted on: 2013/4/1 0:12
They are common in the wrecking yards here in Oregon and Washington.
Posted on: 2013/4/1 0:31
I'm sorry, my mistake, I gave DD an oval port A15 intake and it has the water jackets as well.
Posted on: 2013/4/1 0:57
'73 2 Door Sedan
From Selah, Washington
I'll take a look in the shop tomorrow after work. I think I have one but it would have been modified to fit around a header if I remember correctly.
Mike
Posted on: 2013/4/1 8:23
This manifold can not be used as a wet manifold though. One ear has been welded due to a crack.
Posted on: 2013/4/3 2:30
