compression. what is safe???
From durban, south africa
hey guys,
what is a high but safe compression to run?
currently i'm at 150psi with a 1mm deck plate. if i remove it i should go up to about 170-180psi, would this be safe on pump gas??
many thanks
nicholas
Posted on: 2004/4/30 15:17
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: compression. what is safe???
From Coondle, WA Australia
yeah I think so.
I had a suzuki and only had 150psi when it was supposed to have about 180psi. Different motor i know, but just a comprassion. Actually thats probally not much help. sorry..
Posted on: 2004/5/1 2:38
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Let's see ... stock A12 compression is 9.0:1. You should be able to go to 11:1 on "premium" pump gasoline?
Posted on: 2004/5/1 3:23
