What tyre and offset for 15's
From Mordialloc Victoria 3195
Hi,
Im wanting to know what size 'width and offset' 15" wheel and tyre combo I can fit on my 1200 ute without them rubbing on the control arm or inner guard on full lock. Hoping to avoid buying the wrong ones to start with.
Cheers, David.
Posted on: 2013/4/25 7:50
Re: What tyre and offset for 15's
From MOOROODUC. Victoria
I have 185 / 55 /15's on mine
Posted on: 2013/4/25 10:06
From Logan, QLD
With the guards rolled, I have pushed both boundaries as far as I could.
On the front I have 15x6.5 +16 with 195x45's.
On the rear I have 15x7 +15 with 195x45's (could do 205's just have not replaced them yet).
Pic for reference
Posted on: 2013/4/25 11:28
From WA perth
that's not pushing the boundaries, i,ve got 17/7 /205/40 with 40mm ofset
Posted on: 2013/4/25 12:26
From Logan, QLD
+40? Are you using spacers? They would rub the suspension struts, and the inside back guards, I can't imagine they would fit...
If it were -40 they would be sticking like 60-70mm put of the guards...
Posted on: 2013/4/25 21:36
What tire will fit? Same width, offset and overall diameter as with 13" or 14".
175 width is safe
185 width is tight
195 width is far as you can go on the FRONT with stock suspension and bodywork
Offset: around +15
Diameter should be kept small, 175/60R15 is readily available, but 1-1/2 inches taller than stock tyres.
175/55R15 is even better, it's only 3/4" taller than 12" tires. So they will fit exactly like 175/70R13.
Posted on: 2013/4/25 22:05
From WA perth
The tyre's fit just fine.
Posted on: 2013/4/26 11:11
From Logan, QLD
Spacers on the front? the different diff would explain the rear...
Posted on: 2013/4/26 11:31
From WA perth
no spacers
Posted on: 2013/4/26 12:20
From WA perth
by the way the diff is 20mm wider than a std diff
Posted on: 2013/4/26 12:22
