the duck thats starting to suck ;-)
Things on the duck are starting to suck.... I started working on it tonight to get it on the road. Missing starter bolt.. Fixed, charge light fixed (bad alternator), missing rocker cover bolt had to drill and Tap a thread in head gently. Done. Tighten loose calipers bolt done.
Well drilling and tapping the rocker bolt was ok til I went to put the cover back on, I forgot to remove a bolt from the cover and it fell down the front cover between the chain and cover. Went to get the magnet..... It dropped before I could get the magnet.
Fark! So now motor has to come out. Drained oil hoping it may have worked its way through by luck.... No luck. Would have better chances at tattslotto.
So think I will drop the Sump first, if its not there front cover has to come off, which means head gasket too. Im crap out of luck.
Can I use rtv red or there bond on Sump and timing cover. I have no spare gaskets.
Posted on: 2013/5/6 17:03
Re: the duck thats starting to suck ;-)
When it rains, it pours.
If the bolt made its way to the oil sump, just leave it there. It won't go through the oil pickup screen.
Posted on: 2013/5/6 20:35
Mik, your latest method of lowering the centre of gravity is genius. Three quacks for you!
Posted on: 2013/5/6 22:13
What a raw deal, right there!
Get a hold of auto surplus and ask for a price in those gaskets! Shouldn't cost too much, otherwise it will be a vrs kit... (They're usually peaking busy so call back often if they don't.)
Posted on: 2013/5/6 23:10
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
From Melbourne, Australia
Uh oh. I saw yellow and thought banana, but now I'm thinking of another fruit...
Posted on: 2013/5/7 0:56
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
LEEEEMMMMOONNNNNNNN!!!!!!!!!
Posted on: 2013/5/7 3:19
1200 Ute - Mild A12
The car is far from citrus variety just previous mech work was done by someone with these for balls
jpg  testi lemins.jpg (35.36 KB)
737_51887e7f38665.jpg 246X249 px
Posted on: 2013/5/7 5:08
Wow if he took his glasses off im sure he'd be thinking they weren't lemons.
Cars not a lemon, its a duck that thinks its a super bee.
Well I got the bolt! Right where I thought it would be.
Didn't trust my cranes hydraulic with me lying under car so I cut some wood and used the rhs beam off the crane as such
So I had to drop the away bar the x member, draglink and other stuff but got the Sump off fairly easily. I wanted to best the dents out of it too.
And there it was
So I checked out my bottom end and seemed ok, but I've never seen these marks in a crank before
So put it all back together and found more missing bolts on.car, a manifold bolt, a ball joint bolt. Lucky I like to be preventative.
Need new inner tie rods, rest look newish.
Posted on: 2013/5/7 16:23
From Sydney
The drill holes in the counterweight are done during crank balancing
Posted on: 2013/5/7 22:57
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From RSA
dude you should invest in a magnet. You can buy one of those goodies that looks like a screwdriver and pulls out like a radio aerial they are very handy. I'm sure it would have worked through the sump hole.Anyway you have got it done.Goodluck with the rest.
Posted on: 2013/5/8 6:31
