Tyre and Rim Question
From Sri Lanka
Hi Guys
i got 4 13.5 Rim set that match my bolt pattern and also i got 4 used tyres of (165/70X14 Japanese Yokohama), will i be able to install them on my 13.5 Rims or do i need to buy 14 Size rims for them ? if so what model vehicle rim will be fine that uses rim size 14 ?
thanks
regards
sumith
jpg  tyres.jpg (66.63 KB)
10994_518dbf702503c.jpg 640X480 px
Posted on: 2013/5/11 4:48
Re: Tyre and Rim Question
no offence, but thoes tyres look pretty low in tread anyway.
13.5's onto 14's sound sketch.
best just getting a new set of 13.5" tyres man to suit your 13.5" rims.
but i don't know where you'll find them?
Posted on: 2013/5/11 8:33
14" tires require 14" rims. Put onto any other size they will immediately fail.
Do you mean 13" diameter x 5" wide? Because I have not heard of 13.5" wheels.
Posted on: 2013/5/11 19:51
From Sri Lanka
Hi Guys
The Tires i am running are much verse than these since i got them free just thought of finding a way to use ,ok might be i am mistaken i might have 13.5 Tyre on 14 Rims any way i have seen some 13.5 on the tire or rim i will confirm it by checking them ,
here it is it looks rim are wider the tyre is 13.5 low profile
thanks
regards
sumith
jpg  tttt.JPG (52.35 KB)
10994_519061c1d5d3e.jpg 640X480 px
Posted on: 2013/5/13 4:38
From Narellan,Sydney
As dd said I don't think there is any such thing as a "13.5" rim.it would be a 13" tall rim 5"" wide.which means you need 13" tyres.pretty positive there's no such thing as half sizes
Posted on: 2013/5/13 5:37
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From Sri Lanka
Hi Guys
Look at this tyre, it says 175/60X13.5 so what is this rim size then ? there is no indication on it is it 13 or 14 or 13.5 ?
thanks
regards
sumith
jpg  3.jpg (80.49 KB)
10994_5199a66869265.jpg 640X480 px
jpg  4.jpg (87.87 KB)
10994_5199a67076fe0.jpg 640X480 px
Posted on: 2013/5/20 5:28
Looks like it is a 13.5" rim. L.T. (light truck) tires are available here in 16.5" size (they stopped making 16.5 wheels in the 1980s, but this is the first I've heard of 13.5". It will require a 13.5 wheel (which should be stamped on the rim). Won't fit a 13" or 14" wheel.
Never seen one before, but they are listed on some web sites, such as Trademe New Zealand
http://www.trademe.co.nz/Browse/Listing.aspx?id=538103962
Posted on: 2013/5/20 5:50
