The CA18DE & DET Q&A Thread Feel Free To Q&A
From Armidale N.S.W
Well Thought i would start a thread to help with Plumbing and wiring Questions For All Who have been there and are going there.
Will start it rolling with some plumbing Questions and pics.
Obviously a pipe connects to the circled part of the metal t piece in first pic, Where does it go ?
Do i need the little cannister in Pic numbered 1 ?
Can i block or re route where it connects to in pic
numbered 2 ?
jpg  CA 001.jpg (50.35 KB)
10290_518f76f715dfa.jpg 640X480 px
jpg  CA 002.jpg (50.88 KB)
10290_518f77088fed7.jpg 640X480 px
jpg  CA 003.jpg (50.30 KB)
10290_518f771a492a0.jpg 640X480 px
Posted on: 2013/5/12 12:04
73 1200 wagon SOLD
Re: The CA18DE & DET Q&A Thread Feel Free To Q&A
From Sydney, Australia
Big hose goes to plastic crossover pipe after intercooler but before throttlebody. It is the air feed for the idle circuits. If you block that, the idle wont work. Next is vaccuum cannister for power valve. You dont need it if you want less torque below 4000rpm. Hoses can be rerouted but you must retain the different coloured plastic restrictors and one way valves connected in the lines.
Posted on: 2013/5/12 13:26
Who would want less torque? Isn't more torque better than less torque?
Posted on: 2013/5/12 19:21
Also see last month's topic: what goes where on a CA18
How many times have you looked at all the piping and stuff on a CA18 and said "What tha?"
Found a write up that helps heaps...
Posted on: 2013/5/12 19:25
From Armidale N.S.W
Maybe should have mentioned this is for a DE Engine The other thread all though helpful doesnt tell me where things go on a DE engine and with no disrespect intended it confused me more. Maybe im a bit simple will search the net for pics and hopefully find enough pics to help me.
Posted on: 2013/5/13 10:14
73 1200 wagon SOLD
I have a question as well
I have a Kevin rowley loom and can't figure one of the plugs can anyone help
It's a 2 pin plug wire colours are thin brown and thin grey any ideas :)
Posted on: 2013/5/13 10:40
Car free
From Armidale N.S.W
So nobody can help out here, With all the CA experience surely someone knows.
Posted on: 2013/5/15 10:26
73 1200 wagon SOLD
Anyone know what plug this is for? It's a small brown wire with silver dots and a grey wire with little black dots
Posted on: 2013/5/19 14:27
Car free
From Geelong, Vic
Andy. They are just vacuum lines to run all the vacuum opperated things around the engine. One will go to the intake butterflies, which is what dattodude is referring to when he says you will get less torque below 4k rpm
Only vacuum opperated stuff on my car is the boost gauge, waste gate, bov and fuel pressure reg
Don't run any of the standard vac lines
Posted on: 2013/5/19 20:57
Superfatto, if it reaches all the way to the front panel, then its probably the cold idle solenoid under the throttle body.
Posted on: 2013/5/20 0:58
