Determining if you have matching engine numbers
From Western Australia
Hey guys,
This might be a bit of a n00bie question but I was wondering how do you check if you have the original A12 in you 1200?
I have a 71 sedan so I dont have any plates or numbers on the firewall other than the B120xxxx that is stamped on the LHS firewall. I checked my WA rego papers and the engine number on that matches the engine, is there any other way?
cheers
Posted on: 2013/5/14 1:40
Re: Determining if you have matching engine numbers
A 1971 sedan should have this plate:
The plate includes the original engine number.
Australian-assembled sedans should have a slightly different plate in the same spot:
Posted on: 2013/5/14 2:14
Yea I dont have any of them!? :(
Posted on: 2013/5/14 2:19
1974 1200 Ute - Build
Then the plate has been lost over the years. 42 years old now.
Posted on: 2013/5/14 2:22
so does that mean that there is no way of determining if its the original motor?
Posted on: 2013/5/14 2:24
Probably not.
Posted on: 2013/5/14 3:12
From Melbourne, Australia
Your state transport authority may be able to tell you what engine number it was first rego'ed with
Posted on: 2013/5/14 4:00
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
