« 1 2 (3) 4 »
Re: car wont.start... carby help please
From A-TOWN
you could hardwire the coil straight to the battery, if it still dont spark then you know whats f@*k3d
Posted on: 2013/5/12 23:16
Yep, tried that, tried another 2 coils, same thing
Posted on: 2013/5/12 23:50
From Sydney
ignition key barrel confirmed as working?
Posted on: 2013/5/13 3:22
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
To confirm the ignition key barrel is working correctly:
* Ensure 12V comes out 'S' terminal when turned to Start
* Ensure 12V comes out 'R' terminal when turned to On
Or if testing with the switch unplugged, check for continuity between B and S and then between B and R.
Posted on: 2013/5/13 3:32
Quite a regular
From neerim east victoria
If you have run a wire direct from Bat+ to coil + and tried several coils and still no spark then the problem can only be in the dizzy or dizzy drive remove the dizzy cap and turn the engine over to make sure the rotor button is turning,you may have a damaged dist drive gear[stripped tooth]also to test the coil remove the neg wire from coil attach a temp wire to coil that you can touch on a earth,remove the H/T lead from the coil fit one of your plug leads into the coil with a spark plug attached, earth the spark plug and touch the neg wire on/off on a earth you should have a good spark at the plug if coil is ok,also check the pigtail wire[wire from coil to points]I have seen them broken internally or shorting where they go into the dizzy housing
It's a process of elimination but once you hotwire the coil you eliminate all the ignition switch vehicle wiring[just ask any car thief]
Russ
Posted on: 2013/5/14 0:02
Rotor turns, its set to tdc on first cyl.
Tried again last night, different coils etc. nothing.
Im going to try with some help tomorrow night if weather is clear (will be cold) and if no good then auto elec time.
I have another dizzy coming. I hope the modules are replaceable in series 2 blue bird distributors
Posted on: 2013/5/14 0:59
From Sydney
Good Point, It may be the bosch module in the series II dizzy. The module in mine died from the excess heat in the engine bay fire. Can be had very cheap on ebay. search "BIM024" ignition module. Always handy to have a spare one in the glove box anyway.
Bosch BIM-024 ignition module
Posted on: 2013/5/14 1:48
1970 KB10 Coupe
S13 caliper b...
Yeah just strange as was working fine,when pulled from sedan. Now nothing? Weird for a module. Great link benny.
Posted on: 2013/5/14 2:11
hey unfamilia
You most likely have a burnt out resistor if no spark from the coil meaning the circuit is remaining open.Try changing the resistor and see how you go.the white part near coil.
Also took pics of a friends gx stanza auto. check if your wires to resistor etc are connected correctly too.
I can take pics of other stuff like fuse box etc to compare to yours
cheers
jpg  20130514_161858.jpg (144.79 KB)
15239_5191d9444c9b8.jpg 800X600 px
jpg  20130514_161832.jpg (150.54 KB)
15239_5191d94fb5b45.jpg 800X600 px
jpg  20130514_161709.jpg (139.03 KB)
15239_5191d95a6eb36.jpg 800X600 px
Posted on: 2013/5/14 7:29
and if u did hardwire "properly" from coil to battery then most likely the points in the dizzy are gone..as already stated prob will be dizzy.
Posted on: 2013/5/14 7:42
« 1 2 (3) 4 »
