Tempory Fix for Water Leak
From Sri Lanka
Hi Guys
I have a tiny water drop from my B310 Water return plug located on the dash board side, is there a anyway that i can fix that matter temporarily till i remove that plug and check it later,any glue or something like to fix it ? since i am going upcountry tour most probably this week end , it can run around 100 Km without refilling and heating it has A12A engine on it
thanks
regards
sumith
jpg  5.jpg (49.41 KB)
10994_5199b214e7f58.jpg 400X300 px
Posted on: 2013/5/20 6:19
Re: Tempory Fix for Water Leak
Is the leak inside the passenger compartment or in the engine compartment? The dashboard (firewall) divides the two.
The easiest fix is to bypass the heater (connect the long heater hose to the back of the cylinder head). It usually solves a leak unless the fitting is rusted out.
You may leave it this way temporarily or permanently -- the engine runs fine either way. Just depends on whether you need the heater for de-misting the windshield.
Posted on: 2013/5/20 7:00
From Sri Lanka
Hi DD
It is flowing to the Engine Compartment not to the passenger Compartment , Actually it looks it is leaking from the Plug seal It self not from the rubber hoses and connectors
thanks
regards
sumith
Posted on: 2013/5/20 7:24
Plug seal?
Posted on: 2013/5/20 17:11
From Sri Lanka
Hi DD
I think it is
thanks
regards
sumith
Posted on: 2013/5/21 4:35
I do not known what "plug seal" means.
Posted on: 2013/5/21 4:55
From Perth WA AUS
Just taking a stab in the dark here but Strange backfire and leak near the heater hose connector at the back of the head, could it be blown head gasket?
You could try a little bit of egg white in the coolant as a temp fix but might block more than the leak.
Posted on: 2013/5/21 9:08
Datsun 1200 2Dr sedan.
From Sri Lanka
Hi Leavy
I checked the Oil there is no indication of Gasket failure , i will go through them tonight and let you guys know,
This has been sat for few weeks did not have time for it since i am planning for a upcountry tour for this week end
So doesn't like to Refill Radiator each and every 100 km , so just was thinking about applying gasket maker glue or something similar to avoid that tiny leak, will it work ?
thanks
regards
sumith
Posted on: 2013/5/21 9:21
From Perth WA AUS
Sorry Sumith but until the cause of the leak is determined I cannot say.
It is not a problem (I think) if you carry spare water/coolant and top up as required before overheating.
Maybe also remove the fitting, smear some sealant onto the thread and re-fit before the sealant cures.
Hope this helps mate.
Posted on: 2013/5/21 10:38
From Cape Town ZA
Very easy fix is to pour a packet of curry powder in the radiator. The curry will circulate until it finds a hole where it will bake into a plug. Don't ask me why it works or how, we drove a A14 for almost a year like that, after a welsh plug sprung a leak, before we pulled the motor to rebuild it.
Posted on: 2013/5/21 12:23
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
