need help!
From sydney,NSW
hey guys, i have a problem with my ute...
the car starts up but then sounds like its idling on 3 cylinders... accelerating it does go back to normal but then gets alot of back firing happening like im in world war 3.
i checked the dizzy, and spark plugs. 1 of my spark plugs (cylinder 1) was really black.
i then went and bought new ones and turned my fuel idle screw down and its still happening
in fact its worse. tried my old carby thinking it is a air/fuel mixture but no luck
oh and also at start up and warming up my exhaust is spitting black stuff out!
was wondering if anyone knows what is wrong with it or if anyone has been though the same problem as i am experiancing?
Posted on: 2013/6/6 10:56
Re: need help!
From sydney.nsw
maybe check no1 lead or replace it for trail.
if thats no good, do a compression test on all 4 cyls.
Posted on: 2013/6/6 11:22
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: need help!
From sydney,NSW
thank you bige
i am thinking it is bad rings on the first cylinder...
will test it on the weekend
Posted on: 2013/6/6 11:43
Re: need help!
From sydney.nsw
if thats the case.i can supply you with engine parts if required.cheers
Posted on: 2013/6/6 12:36
Re: need help!
From sydney
I had this issue with a fresh rebuild, I replaced the plug and corrected the timing and it was perfect after that
Posted on: 2013/6/6 13:54
Re: need help!
From Stone Age somewhere in U.S.A.
Bad plug wires, worn cap and rotor, carbon tracking inside the distributor cap? Changing the spark plug got rid of one possibility, But check the other stuff before blaming it on something major. Also it would be a good idea to check the valve adjustment, if they are tight, it could cause similar symptoms.
Posted on: 2013/6/6 14:43
