Will This Fit My B210
From Sri Lanka
Hi Guys
i am Looking for i used Alloy Wheel Set for my b211, and found this little Cheap and good for the price , only my concern is its offset ? what do you suggest ?
http://ikman.lk/en/13-alloy-wheels-for-sale-colombo-1#
thanks
regards
sumith
Posted on: 2013/6/11 5:19
Re: Will This Fit My B210
The offset looks to be pure Front-Wheel-Drive ... too much offset for a B210/B211.
jpg  wheels.jpg (22.73 KB)
174_51b6b99c1f0c9.jpg 512X256 px
Posted on: 2013/6/11 6:46
From Sri Lanka
Hi DD
Thanks, I also thought so
regards
sumith
Posted on: 2013/6/11 6:49
From Sri Lanka
Hi Guys
http://datsun1200.com/modules/mediawiki/index.php?title=Chasers
Compatible Wheels section
Says It should have 71MM Center Bore to fit for datsun 1200s but i was unable to find Any Wheel Above 70 most of them are 60-67 is it a mistake or am i mistaken something here ? What is the Actual Center Bore size of datsun 1200 ?
thanks
regards
sumith
Posted on: 2013/6/11 9:10
70mm is the centre bore. Mine were drilled based on 70mm and are perfect.
Posted on: 2013/6/11 12:29
From Sri Lanka
Hi Guys
http://ikman.lk/en/13inch-alloy-wheels-for-sale-colombo
This is from Maruti Zen 2003 Model has good Offset and it is 114.3 PCD i think, Need a Repaint too, what are the suggetions ? is it repaintable one ?
Zen Specs Says it has
4.5J x 13 wheel
and also i went through google search by bolt pattern i could not find any wheel with 70MM + Center Bore
http://www.roadkillcustoms.com/hot-ro ... dInch=&StudSpreadMM=114.3
thanks
regards
sumith
Posted on: 2013/6/12 8:19
Edited by Sumith on 2013/6/12 8:59:01
The center hole can be bigger than 71mm, as the wheel locates on the taper lug nut holes.
Posted on: 2013/6/13 1:42
