Browsing this Thread:   4 Anonymous Users
Foot well and wheel well
From Goulburn NSW
Hi guys is the foot well and wheel well one piece or is it separate.Just thinking about bashing it in,will it be noticeable from the inside?
Posted on: 2013/6/19 6:01
Re: Foot well and wheel well
From MOOROODUC. Victoria
One Piece
Posted on: 2013/6/19 6:17
From Narellan,Sydney
Should only need bashing if the wheels are around the 17x7ish or bigger I'd think.front runners would fit easily
Posted on: 2013/6/19 7:02
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From South East Brisbane
My 13x6's rub on the wheel well on turning, I have a feeling its because I haven't adjusted the steer stopper bolt on the LCA properly.
Posted on: 2013/6/19 7:27
datsunikon (fb) | datsunikon (blog)
From Goulburn NSW
I going 18" on the front much to everyone discuss but I quiet like the look.As I have said in another post I might get away with it because my whole front end will be adjustable so I might just have to trim the front off the guard.
Crab45 it could be the bushes on the caster bars too,mine were rooted so I put new ones in and fixed it straight away.
Posted on: 2013/6/19 7:49
Not the bushes, they've all be replaced, hasn't driven 100m on them haha.
I'll play with the steering lock thingo on the LCA after I get new tires.
Maybe going from 175/65 to 165/55 will do the trick for me.
Posted on: 2013/6/19 7:58
From Goulburn NSW
On the ute I sold last yr I had 175/70/13 on they were fine,but then again I don't know what had been done by the previous owner.
Posted on: 2013/6/19 8:07
You will struggle MASSIVLY to clear the foot well with 18s.you can't drag it forward that much to make it work let alone evan have them turn.unless you driving it 12" high they just won't fit. Good luck to you but
Posted on: 2013/6/19 8:25
18's ???
what profile tyre are you thinking of ... or are you planning just a thin strip of solid rubber???
Posted on: 2013/6/19 8:29
From Goulburn NSW
Well guys I have put an 18" on the front off my datto and will need to much work to make them fit,and yes they look dumb.So now ill go 17" front and 19" rear.
Posted on: 2013/6/21 8:51
Edited by mcdat on 2013/6/21 9:13:55
