CA18DE loud noise
From MOOROODUC. Victoria
I think I have a big problem .... anyone out thee got any other ideas???
Compression tested 170 130 170 170 number 2 is 25% down (not good) Tested last week all at 170
Timing is ok about 13 degrees BTDC
disconnected one coil pack at a time - noise unchanged
checked with car under load - it got worse
no oil in water or water in oil
no codes on ECU (detonation code 34 now gone)
my guess is a bearing
Posted on: 2013/7/7 8:03
Re: CA18DE loud noise
From Melbourne, Australia
argh what a shame!
i dont think simply a bearing would drop compression
Posted on: 2013/7/7 8:07
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
so if I am lucky it might be a spring in the head on cyl 2 ... second guess
Posted on: 2013/7/7 8:14
perhaps valve noise you mean?
have you listened to the motor by pressing a large screw driver in different areas with your ear on the back of the screwdriver? you should be able to tell if its coming from top end or bottom
Posted on: 2013/7/7 8:24
1200 Coupe Rallycar
Did you do a wet test too?
No loose nuts fell into inlet etc?
Posted on: 2013/7/7 8:50
Wet test?
it's been running for months without any major work .
I am thinking that when I connected the detonation sensor it has done something via the ECU ... maybe I had the timing too far advanced previously making up for the detonation sensor not working and then hooking it up without resetting everything has damaged something ...
I did run it for a while on I heard the noise
then again I could just be rambling on
Oh Michael ... yes listened for the knocking and heard it mainly in the top
Posted on: 2013/7/7 8:56
Wet compression test. Little bit of oil through spark plug hole. If comp comes up its rings. Otherwise valves id think.
Posted on: 2013/7/7 9:34
hydraulic lifters are getting over 20 years old for most CAs, along with valve springs losing tension it could be just one Lifter sticking from build-up.
Posted on: 2013/7/7 12:32
