« 1 (2) 3 »
Re: half counterweighted L18 crank
From Malaysia
supercharge, because you bring missiles to a gunfight. Lol
usually ford guys put l18 crank in their crossflow in malaysia.
Posted on: 2013/7/6 8:48
Yep the Kent can be almost as reliable as an L :)
But this L is just inspiring...
LOL - 5.38 to 5.52
I cry like a little girl from
8.50 and best sound gearing up at 9.02
http://www.youtube.com/watch?v=6IOJOwZomUU
Posted on: 2013/7/6 13:28
From Malaysia
hey D i finally have the picture you've been asking for LOL. phone camera sucks.
these are pictures from W53 head i have here. closed chamber, notched port. those valves are 35mm ex 42mm in
Posted on: 2013/7/16 13:30
I have a w53 here too. Comes on stanza l16
Posted on: 2013/7/16 13:48
From Malaysia
from A10 isnt it? any source i find on the net says W53 is for injection engine but here our PA10 is twin SU. these W53 came standard. they do wear SSS badge.
Posted on: 2013/7/16 13:50
Yes pa10
Posted on: 2013/7/16 14:45
From stinking hot cairns
every efi head I have seen including my own is an A87
Posted on: 2013/7/16 21:43
massive valves, I didnt think the aussie w53 has this size valves only on the L20 heads, I can see why they can easily go 47mm inlets on works L donks very little shrouding. Big M you should also join Ratsuns website alot of L afficionados there and reckon you could even inject that engine using ca18de nistuned ecu, tb and modded ca18de plenum.
Posted on: 2013/7/17 1:42
Edited by D on 2013/7/17 3:11:42
they look pretty much the same as my w53 valves.
[/URL]
[/URL]
Posted on: 2013/7/17 9:14
calc on Ozdat has L16 SSS head as 42mm x 33mm and stock L16 38mm x 33mm but maybe should be 40mm x 33mm?
http://www.ozdat.com/ozdatonline/enginedesign/
Posted on: 2013/7/17 9:27
« 1 (2) 3 »
