speedo help pleaseeee
Quite a regular
From gold coast, qld
Hey dudes just wondering , I've got a 5 speed 1200 Ute 78 model , so gearbox and wheels / tyres aren't stock either , I'm in Australia with klms and was just seeing how I would get my Speedo accurate , like how wouod I go about doing that , I think its out by about 20-30ks , cheers
Posted on: 2013/7/16 13:01
Re: speedo help pleaseeee
What percentage is it out? 30km @ 100 kph? (30% error) or 30km @ 50 kph (60% error) ?
Next, is it 30% slow or 30% fast?
Then, find out which gear is in the gearbox. If it is the standard 17-tooth gear, add or subtract the percentage. 17+30%=21 tooth or 17-30%=12 tooth. Buy the right gear from Nissan. They come in 16,17,18 or 19 tooth versions. Anything else can use a ratio converter box from a speedometer shop or racing shop. See http://datsun1200.com/modules/mediawi ... =Speedometer#Drive_Ratios
Posted on: 2013/7/16 21:31
Quite a regular
Ok cool thanks so much dude your always a great help , and yea I think its 30 at 100 , and I think Its showing me faster then what I am going if that makes sense , does it matter about the wheels not being stock either ? Or will your way work with them aswell as the hear box
Posted on: 2013/7/16 21:48
From sydney
hi nugget182,check this website out www.bogaard.com.au.this company sells digital speedometer,all you do is simply plug it into the cigarette lighter.
thanks
Posted on: 2013/7/16 22:57
From Sydney, Australia
Borrow a gps and drive at the different speed limits (using the gps speed) and write down what the datsun speedo is showing. Getting a different speedo drive to suit the wheels/tyres is whats needed. Using dots of 'white correction fluid' for 50,60,70,80,90,100,110 on the speedo glass is the ghetto way to fix it.
Posted on: 2013/7/17 9:06
