« 1 ... 4 5 6 (7) 8 9 10 ... 57 »
Re: Datsunbeginner becomes an expert - Vanilla ute build
From Brisbane, Australia
Good to see you still at it.
Just use a bit of angle for the g'box mount, and plates through the floor like the CA guys use.
Don't reuse split/cotter pins.
Posted on: 2013/7/24 7:36
From MOOROODUC. Victoria
it's all lovely white
split pins I reuse, unless they have been bent too many times
As for the mounts my CA uses original mounts, pity you can't get some welded in
Posted on: 2013/7/24 8:29
Thanks guys. Are cotter/split pins the things that go through the bolt and castle nut and you bend with pliers? If so i got all new ones
Posted on: 2013/7/24 8:48
Although the new ball joints had lock nuts instead of castle nuts
Posted on: 2013/7/24 8:49
Re: Datsunbeginner becomes an expert - Vanilla Ice ute build USA
Moving along, the last stretch of the photos of the 10 day build. I installed the existing front struts for the ute. I suspect they came from a 1200 coupe as did the original leaf springs, but I do not know for sure. How do you confirm? The brakes are completely missing but I have the bits and pieces in a box. I will have to learn how to do brakes in the future. The rear brakes have also been stripped down to bare on the diff and will need rebuilding.
The struts have dodgy coil springs with a severe size chuck missing from each of them. I have no idea how tall they are meant to be but mine are roughly 12" - 13" high (unsprung). Needless to say, as they are zippy tied onto the strut shaft, they are in need of replacement. They look great on the ute but are dodgy as anything. Is it okay to reuse the pins that connect the struts to the steering nuckles (4x) ?
If anyone knows a good place in the USA to buy bolt-on upgraded strut/brake setups please let me know
Original rims. 14" x 6.5" Performance Challengers. Bridgestone Eager tires with a slight bulge, that old school muscle car look.
jpg  P1010482.jpg (134.22 KB)
13419_51f7a9772d7b7.jpg 800X533 px
jpg  P1010483.jpg (176.87 KB)
13419_51f7a97cc434d.jpg 800X533 px
jpg  P1010484.jpg (152.19 KB)
13419_51f7a9821b4b7.jpg 800X533 px
jpg  P1010485.jpg (180.18 KB)
13419_51f7a9875a3f9.jpg 800X533 px
jpg  P1010487.jpg (160.51 KB)
13419_51f7a98c5d544.jpg 800X533 px
jpg  P1010488.jpg (134.48 KB)
13419_51f7a99199689.jpg 800X533 px
jpg  P1010493.jpg (174.49 KB)
13419_51f7a996f2af1.jpg 800X533 px
jpg  P1010494.jpg (198.59 KB)
13419_51f7a99e97182.jpg 800X533 px
jpg  P1010496.jpg (141.09 KB)
13419_51f7a9a53bd13.jpg 800X533 px
Posted on: 2013/7/30 12:55
In picture 493...View of left hand tire, there is a bit of a gap between the steering knuckle and the strut...is this normal?
Posted on: 2013/7/30 12:58
Techno toy tuning in the USA do good bolt in kits
Posted on: 2013/7/30 12:59
Car free
Oh yea, and the ute is now knicknamed "Vanilla Ice"
Posted on: 2013/7/30 13:00
Comin on strong.... no there should be no gap between knuckle and strut base. Now maybe it needs some hammer time
Now let the dj revolve it
Posted on: 2013/7/30 13:22
I want some struts that are smooth as ice.... ice.... baby
Thanks supa, I would have love to have got a set from you but ran out of time. Yea mik, I will see what the deal is, more than likely I replace the whole front strut/brake anyways.
Posted on: 2013/7/30 13:49
