« 1 ... 4 5 6 (7) 8 9 10 »
Re: A pretty lame intro :(
From MOOROODUC. Victoria
Looks very clean.
is it staying as is or are there plans?
Posted on: 2013/7/23 22:58
nice coupe. Did you get that from chick?
Posted on: 2013/7/23 23:37
From vancouver, wa. usa
Yeah, its had a long line of owners, but I got it from dave.
Just putting together parts atm. I have so far, an su manifold, a14 short block, h150 diff, dual piston b210 rear backing plates, sway bar,
What I need is, needles and seats, goodish oval port head, and a 5 speed.
No firm plans but to drive and enjoy it.
Posted on: 2013/7/24 9:30
72, 1200 coupe
77, 710 2 door sedan
http://nwdatsuns.com/viewtopic.php?f=10&t=157
There are more pics here, but I will try to keep it updated here aswell.
Posted on: 2013/7/24 9:32
72, 1200 coupe
I have a 5-speed for $350.
The factory twin Hitachi carburetors (SU-type) use the same needle and seat as the the stock downdraft Hitachi.
Posted on: 2013/7/25 1:47
That could be a good deal for a 5 speed, wich model?
Thanks for the tip on the needles. I will look into that.
Posted on: 2013/7/25 5:46
72, 1200 coupe
It is a 60-series dogleg 5-speed, from a 1979 B310.
Posted on: 2013/7/26 1:37
Ok thanks, im mostly keeping an eye open for a junk yard 63a. Ive allways had good luck with those.
Posted on: 2013/7/26 1:40
72, 1200 coupe
Did get a h72 today. Should work ok for me.
This.porticular one is drilled out for bothe manifold patterns. Should probably check the oil passeges I guess. See if its modded for a12.
Posted on: 2013/7/26 1:44
72, 1200 coupe
Kinda see where I marked the su manifold to the port.
Posted on: 2013/7/26 1:45
72, 1200 coupe
