alloy oil pan
take one nissan cherry E10 oil pan,
cut the deep sump
weld on a wide sump
A12 sump from E10
Modified for RWD use
jpg  E10_oil_pan_conversion.jpg (47.12 KB)
174_4ee95a9e26950.jpg 620X465 px
Posted on: 2011/12/15 2:25
Re: alloy oil pan
From Las Vegas USA
Dave I have an extra dry sump pan that I contemplated doing that with...........how much does that increase the oil capacity?
Tom
Posted on: 2011/12/15 2:36
Re: alloy oil pan
The oil capacity depends on how big a a sump you weld to the alloy pan.
The Datsun Cherry 1971-1975 has an alloy pan. Cut off the superdeep sump and weld on your choice of sump-box to make a wider, shallower sump.
Posted on: 2011/12/15 4:09
Re: alloy oil pan
From Tasmania
you guys stay away from Tasmania!
Posted on: 2011/12/15 5:19
Proud member of " The Tasmanian Datsun Owners Group"
Re: alloy oil pan
From Townsville, Qld
You've never seen a wombat angry until you've gone and started chopping up his alloy, they use that stuff in the burrows you know
Posted on: 2011/12/15 6:40
Re: alloy oil pan
I have one of these alloy oil pan, if i decide to modify the bottom... what is the real level of oil ?
Posted on: 2013/7/30 3:49
Re: alloy oil pan
The real level of oil won't change. The dipstick measures the correct level relatively to the crankshaft, so it is independent oil oil sump shape.
Posted on: 2013/7/30 5:44
Re: alloy oil pan
From Goulburn NSW
Hi guys whats the advantage off this style off sump?
Posted on: 2013/7/30 6:56
