F5C56A Input / Output Shaft Seals
From Cambria, California
Are the F5C56A input & output shaft seals the same part number as the 56A 4 speed seals?
How about the throwout bearing fork, throwout bearing and clutch slave cylinder - will these interchange between the 5-speed and the 4-speed? I'd like to gather the proper bits before I send my F5C in for dismantle, cryo and REM treatments. Thanks in advance!
Posted on: 2013/8/18 0:06
Re: F5C56A Input / Output Shaft Seals
Release Lever
Release Bearing
F5C56A didn't use a clutch slave cylinder, it used a cable clutch system. It appears to have the same basic front case casting as the 4-speed, so can be drilled & tapped to use the same slave cylinder.
Posted on: 2013/8/18 1:09
Edited by ddgonzal on 2013/8/18 1:29:54
F5C56A Transmission Seals
Nissan 32113-H3100 SEAL-OIL FRONT COVER
Nissan 32136-G1001 SEAL-oil, rear extension
4-speed Transmission Seals
Nissan 32113-H3100 SEAL-OIL FRONT COVER 4 SPEED
Nissan 32136-G1001 SEAL-OIL REAR EXTENSION 4 SPEED 1072-
Posted on: 2013/8/18 1:30
Thanks DD! Good timing on this...Rock Auto is having a spring cleaning sale on many 1200 bits right now, these seals included.
Posted on: 2013/8/24 19:27
