« 1 ... 32 33 34 (35) 36 »
Re: H165 LSD's FOR SALE
hey bud, h190 diff, strong enough for 12a rotary, not sure if turbo yet. do you do complete with brakes? cheers
Posted on: 2012/8/11 14:53
From Townsville, Qld
So I got my diff back and a couple of questions.
1. This being a first batch 165 unit, was there any spacing issues found from members? I ask because this particular one had to be machined ever so slightly to remove the need for a shim on the crownwheel (the concensus among the shops involved were that shimming the crownwheel was going to be a point of failure).
2. It is setup with 0.5mm of backlash, is this acceptable?
3. what's a good fluid to run in this diff now? (haven't installed it yet)
Posted on: 2013/8/24 2:02
Posted on: 2013/8/24 2:26
That was implied DD, I just don't want to put jello in my diff when there is something that works good.
Posted on: 2013/8/24 3:29
It is my understanding that Nissan recommends normal diff oil for Nissan vehicles using that sticker. So it is misleading. Just a high-quality GL-5 oil, synthetic oil is not required. 80W-90 is the usual, but depending on temperature other viscosities may be used (75W-140 for example).
What would be more interesting is what the LSD manufacturer (topgear in this case) recommends.
Posted on: 2013/8/24 3:53
From Adelaide
Aren't these a torsen type centre? i.e. no friction plates or viscous plates and therefore normal diff oil? The friction modifiers are for the clutch plates (I believe).
I can check my manual on the backlash tomorrow if no one else responds.
Posted on: 2013/8/24 12:40
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
my mate did some checking and came up with 0.5mm as being acceptable, just wondering if other people have set more\less for racing applications?
Posted on: 2013/8/25 1:40
As it is I am in a bit of a spot where I can't tell if I my gearbox is broken or the H150 diff, can't get the drain plug off the box to check the oil for decent shavings, though with the amount of backlash the diff has in the car and oil seepage I wouldn't put it past the dif to have rooted something.
Any torque applied in 3rd adn 4th (or high in second so has to be output speed based) brings out a hell of a whine and scratching (the scratching should be sorted out as some bolts were scratching the tailshaft)
so with that in mind I thought it'd be a good time to switch in the new diff ect while I work on the W58
Posted on: 2013/8/25 1:46
My FSM says for H165:
Ring Gear
Backlash between ring gear and drive pinion mm (in)
0.13 to 0.18 (0.0051 to 0.0071)
So the official Datsun specification is very tight. Much tighter than 0.5mm.
R160: 0.1 to 0.2 mm
H165: 0.13 to 0.18 mm
H190: 0.15 to 0.20 mm
Posted on: 2013/8/25 2:11
dam.
Posted on: 2013/8/25 3:16
