(1) 2 3 »
Weber tuning?
From Trinidad and tobago
I have a Weber 32/36 On a standard a15 but i would like to kno of all the jets to put in it, idle air correction main etc and have it running nicely with best throttle response. Thanks!
Posted on: 2013/8/25 3:06
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Weber tuning?
From Townsville, Qld
145\155 main jets
160\165 air correctors (if you have bigger try those first)
3.5\4.5 venturis
45 accel pump jet
f50 emulsion tubes
45 or 50 idle jets
for the mains you could try smaller say 135\145 but there's a high chance that's too lean
Posted on: 2013/8/25 3:20
Re: Weber tuning?
Yes, that'll work OK. So will this:
Main jets: 140/140
Emulsion tubes: F50/F50
Air correction jets: 170/160
Idle jets: 60/50
Jump jet: 50
Needle valve: 2.00
Posted on: 2013/8/25 3:23
Re: Weber tuning?
Mines are i assume
140 150 Main
185 190 Air correction
50 55 idle should i leave ilde as is?
Posted on: 2013/8/25 3:55
Street Sleeper!
Re: Weber tuning?
Unknown. How does it run with those tuning parts? If it is perfect, don't change them.
Posted on: 2013/8/25 4:01
Re: Weber tuning?
Not performing perfect atm.I guess am running to lean o air correction? Using next size smaller may tip in the circuit sooner holding out on the trasitional overlap
Posted on: 2013/8/25 4:16
Street Sleeper!
Re: Weber tuning?
Why mess around? Use the tried and true jetting for A15 engine.
Posted on: 2013/8/25 4:30
Re: Weber tuning?
Im not messing around im just trying to find out the true jetting for it.
Posted on: 2013/8/25 14:00
Street Sleeper!
Re: Weber tuning?
From Snohomish, WA USA
Stick with the factory settings. If your lean and you want to tweak it, go richer on the primary side then on the second side. I've never had good results going richer on the secondary side.
Posted on: 2013/8/25 16:49
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Re: Weber tuning?
I was working on a mate's hilux with 32/36 and the primary jet was bigger, never knew why we found it like that
Posted on: 2013/8/26 2:32
(1) 2 3 »
