WTB Cross Member
From Port Douglas. QLD
Hi
Im chasing either a standard crossmember for a 1200 ute or a maddat ca18 crossmember.
I have an L20 on a modified crossmember (unknown) in the ute at the moment. Contacted maddat but they only have the crossmembers as an exchange item :(
Cheers
Posted on: 2013/8/28 10:59
1200 ute
ca18det
Re: WTB Cross Member
i have some stock ones.
Posted on: 2013/8/28 13:32
pm'd
Posted on: 2013/8/29 10:39
1200 ute
ca18det
From Logan, QLD
Do you still want the l20B one, I'll swap for free either a ute one or old style for it.
Posted on: 2013/8/29 11:41
From Logan, QLD
or some money your way depending on the condition/quality of fabrication/position.
Posted on: 2013/8/29 12:09
Won't the L20B crossmember work with the CA engine if you use 1600 rubber mounts?
1200 crossmember modified for CA engine
1200 modified for L-series engine
The Maddat conversion crossmember is a thing of beauty and a great choice.
Posted on: 2013/8/30 2:33
From Gold Coast Queensland, Australia
If you found one would you sell the one you've got Mr Barista?
Finally fitting the L20b in mine
Posted on: 2014/9/2 10:21
From Goulburn NSW
I also would like a ute crossmember if anyone has one,not in a hurry.
Posted on: 2014/9/3 2:56
