Kangol belts
From Sydney, NSW, 2036
Hey guys,
I have a set of KANGOL seat belts in the sedan. these are period correct, and are merely a lift clasp type belt.
Can you get registration with these belts? I think you should be able to as they were approved in the day.. whether or not they are still safe is debatable I suppose.
Im considering installing new belts with a drop loop for safety.
Who still uses these belts?
Cheers
Ed
Posted on: 2013/9/16 5:05
81 Datsun ute
Re: Kangol belts
From Christchurch NZ
They should be fine.
I actually really like them. (If they're the same ones I'm thinking of)
They undo no worries when they're under tension. I was upside down in a car once, gave the handle a flick, and was out in a flash.
Posted on: 2013/9/17 9:35
Forced Induction!
Re: Kangol belts
From stinking hot cairns
They sound like the standard sedan belts. that's what's in mine and it gets rego in NSW. Do you have a pic?
Posted on: 2013/9/17 9:45
Re: Kangol belts
Yep theyre just standard belts.
they are a black plastic flap which the metal buckle (hook) latches onto.
Can post a pic later... I think I'll use them, I tried one out yesterday and it was just a simple flick as you guys said and it was off.
Cheers
Ed
Posted on: 2013/9/17 22:46
81 Datsun ute
