Another stumpy question....bearing which one?
From Port Douglas. QLD
so which bearing is the right size for the ca bell housing that i have to replace it with?. Is it from the ca gearbox?
Posted on: 2013/10/14 4:55
1200 ute
ca18det
Re: Another stumpy question....bearing which one?
found the thread. end
Posted on: 2013/10/14 4:59
1200 ute
ca18det
OK, so its the NSK not NGK bearing....B2219C3ur
Called nissan and two parts stores and got nothing....any other suggestions? i can find it on google but nothing in aus?
Posted on: 2013/10/14 10:45
1200 ute
ca18det
From Armidale N.S.W
In my experience all the CA and L series 5 speed boxes use the same thrust bearing i have one here for L series TRX Bluebird 5 speed still in the packet. And i got one with a new clutch kit for CA18.
Posted on: 2013/10/14 11:16
73 1200 wagon SOLD
Hey Datsandy,
THanks for the reply but its the countershaft bearing i need to replace so it sits snug in bell housing.
I just found another part number somewhere on the web, but when i call places up here it seems to hard... Thats Far north queensland for you though.
Posted on: 2013/10/14 11:22
1200 ute
ca18det
From Geelong, Vic
Dont have any bearing suppliers in your area? There is one near me that has a book with a listing of every bearing in gearboxes for different cars. They would be able to find it easily
Posted on: 2013/10/14 12:23
You can buy the bearing from NGK or any bearing supply company. Just give them the NSK number and they'll look up the cross-reference. Bearing supply companies will be far less expensive than Nissan. For Nissan you would need the Nissan part number.
Posted on: 2013/10/14 18:02
From Armidale N.S.W
Oh sorry mate. When i swapped the bellhousing over from a ca box to the stumpy it just went on i didnt swap any bearing. Think my box is 240k one though not sure if there any different to R30 stumpy.
Posted on: 2013/10/14 21:52
73 1200 wagon SOLD
