smoke and oil from rocker cover breather?
From vic
hi so after installing new cams valves and springs at high rpm it smokes from the rocker cover breather and leaves a patch of oil on my bonnet
it dosnt do it until you hit around 7000rpm or free reving it smoke 7000 to 8500rpm
car drives great has new rings etc 175psi compression on all cylinders
never did it before the new cam so it must be normal for smoke at high rpm? theres no oil burning smoke out the exhaust
also dont have anything hooked to the breather yet just venting out to atmosphere
Thanks!
Posted on: 2013/10/29 8:36
Re: smoke and oil from rocker cover breather?
From Adelaide
The answer's in the last line! If you don't have PCV it will vent oil vapours/ blowby gasses out the breather. (There's always blowby, it just increases with wear.)
Posted on: 2013/10/29 8:58
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From vic
the engine block breather pipe is on the pcv
the rocker cover breather is usualy on the air cleaner base but mine goes to the atmosphere at the moment
Posted on: 2013/10/29 9:07
From Adelaide
Probably need a bit more info then, like what carb(s) manifold etc. Might be worth checking that you're getting vacuum to the rocker and if not if there's a blockage or fault somewhere. I fresh engine with a working PCV system should suck air at the breather. I rebuilt a 253 years ago and it would squeal (sucking air) through the oil filler cap until I put the right breather setup on it. Would suck your hand on when you put it over the hole.
Posted on: 2013/10/29 9:31
The new valve seals may be leaking. It is not normal
Posted on: 2013/10/29 19:19
