1.5" Dellow lowering block kit - Datsun 1000-1200 $60
From Brisbane, Australia
Brand new, unused. For Datsun 1000 & 1200, not suitable for 120Y. $60
Posted on: 2013/10/30 3:47
Re: 1.5" Dellow lowering block kit - Datsun 1000-1200 $60
Posted on: 2013/10/30 4:32
From Townsville, Qld
I found that out the hard way too Harry, I have a set here if someone wants to buy an additional set. That said if you welded a reinforcement plate on the spring seat, drilled a smaller hole and ran a bolt through the spring pack instead of the pin they could work on a 120Y.
Posted on: 2013/10/30 5:07
the blocks are no problem, its the U-bolts. 120Y H150 and BW68 diffs have larger axle tubes than 1000 and 1200 H145.
Posted on: 2013/10/30 11:50
ah yes, bloody dellow!!
Posted on: 2013/10/30 12:50
It's not Dellow's fault, they don't say the kit is for 120Y. It is for 1000-1200 and give the dimensions and tell you to do your own measurements to check. I bought first and checked later! Now it's a bargain for a 100 or 1200 owner who wants to lower their car quickly and easily.
Datsun 1000 - 1500 Lowering Blocks - 1.5"
1000-1200-1300-1400-1500
This Datsun 1000-1500 Lowering Block Kit is perfect to drop your car body down 1.5" to give that lowered look. Made from cast aluminium, these blocks are strong and come with 4 U-bolts and 8 Fixing Nuts.
Suits the following models:
1000 - 1200 - 1300 - 1400 - 1500
Dimensions:
Blocks
Width - 45mm
Length - 115mm
Height - 38mm/1.5"
Pin Size - 15mm
U-bolts
Internal width - 57mm
Length - 260mm
The sizes listed are a guide only and you must do your own measurements as models do vary.
Posted on: 2013/10/30 22:10
From A-TOWN
Still got these?
Posted on: 2014/11/11 19:37
From Perth
They don't quite match these dimensions for a 1000
So not sure if Dellow or the drawer of this pic are wrong re them fitting a 1000
http://datsun1200.com/modules/myalbum/photo.php?lid=20248
Posted on: 2014/11/12 10:07
