Automatic Gearbox Fluid?? vacuum??
From Lisboa-Portugal
I got my datsun rolling again but i notice a noise and that the gears are not enganging at the right rpm. Could this be related with the gearbox oil level that is a bit low? Can i refill through the dipstick checker?
Thanks
Posted on: 2013/10/31 11:11
Edited by Bandit_blues on 2013/10/31 16:35:35
Re: Automatic Gearbox Fluid
From Kelmscott Western Australia
Thats how you fill auto trans through the dipstick car has to be running in park
Posted on: 2013/10/31 11:32
thank you!cheers
Posted on: 2013/10/31 11:50
Re: Automatic Gearbox Fluid?? vacuum??
I found that the vacuum controler in the gearbox isn`t connected to anywhere, can this be the cause? where do i connect in my A14?
Posted on: 2013/10/31 16:44
Yes that will cause shifting problems.
1. Check fluid only when hot, after driving for 10 minutes. while engine is running
2. Connect the modulator to the intake manifold vacuum
See Automatic Transmission
ads//
Posted on: 2013/10/31 17:27
thank you D, the thing is, i can`t find it in my A14 engine, it doesn`t seam to have any place to plug it in! Does anyone have a photo of the right location?
cheers
Posted on: 2013/10/31 21:52
From Sydney, Australia
On an auto engine there is a boss on the top of the rear most intake manifold runner.
A 180degree hose feeds a hard line that plugs into the right angle hose in your picture.
Posted on: 2013/10/31 23:32
It can be connected to ANY manifold tap. Bottom, side front or top does not matter.
Posted on: 2013/11/1 0:40
Thank you guys!
Posted on: 2013/11/1 7:46
