Good second hand Ca18de pistons
Im after a set of good pistons
will get new rings myself but
prefer some that have done less
than 200,000kms.
Posted on: 2013/11/15 4:21
Re: Good second hand Ca18de pistons
From MOOROODUC. Victoria
I have 3 good pistons that you can have and one in a million pieces
You can have the whole bottom end for free if you come get it
Posted on: 2013/11/15 7:01
PMd
Posted on: 2013/11/16 0:53
Also have a CA18DE block out of an EXA in bits ... block was hottanked.. that cost me $150. Willing to sell that one for that if anyone's interested ... I can sweeten that by adding bits from my stockpile
Posted on: 2013/11/16 8:46
Edited by demacoz on 2013/11/16 20:30:08
From Chipping norton sydney
I have a set of forgies forsale cheep used for one dyno let me no no 0403934939 cheers
Posted on: 2013/11/16 9:46
just need a spare set of DE slugs to fit to a test A series thats getting sleeved as a trail setup. The pistons will be milled -1.5mm using slightly longer a12 rods in A10 block and crank for final 1277cc capacity. If this works out then will sacrifice my only but good A15 block for the same thing but with new slugs to suit valve flycuts for a higher lift cam.
I could rip out 4 pistons from the wreckers but would be a pain in the neck in a fwd ca18de as avail atm.
Posted on: 2013/11/16 14:17
