« 1 ... 48 49 50 (51) 52 53 54 ... 97 »
Re: Super Bee KA24DR Mod
Drat! The videos don't appear in my Google browser (I'm using Android 4.0).
http://youtube.com/watch?v=2clf8XZfm4E
Posted on: 2013/12/3 5:11
From Snohomish, WA USA
Reposted this since DD brought it to the next page.
Found this one on Youtube.
This Bug use to kick my butt prior to this year.
He actually got a jump on me but I caught up.
http://youtube.com/v/2clf8XZfm4E
Posted on: 2013/12/3 5:16
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From Vancouver, Wa
Very nice Ernie, looking very good i haven't been on here in awhile.
Posted on: 2013/12/10 0:28
1969 Datsun 1000 (B10)
1972 Datsun 1200 coupe (ADVAN)
1981 Datsun 210(B310) 4-door (sr20det)
1971 Datsun 1200 (sedan)
Hey Dave, thanks for the comment. I will some day get to Portland and race.
Worked on the Ford 8.8 today. Got it wire wheeled and painted although I will have to re-wire wheel it when I weld the leaf spring brackets on. The axles should be here tomorrow. I just need to pick up some more steel tomorrow for the leaf spring brackets and I plan on reinforcing the welded tubes.
Also, here is a picture of the old Datsun 320 13 spline axle compared to the Ford 8.8 28 spline. The 8.8 outside diameter is 1.22 inches compared to the 320's 1.14 inches but with the 320 being a 13 spline, the strength is weakened by the deep grooves.
Another project soon to be finished.
jpg  IMG_20131211_110501_484.jpg (159.92 KB)
39_52a946a83994c.jpg 816X459 px
jpg  IMG_20131211_121953_068.jpg (174.34 KB)
39_52a946b456145.jpg 816X459 px
jpg  IMG_20131112_132250_246.jpg (105.56 KB)
39_52a946bf91cdf.jpg 459X816 px
Posted on: 2013/12/12 5:17
'73 2 Door Sedan
Ok, more work done today and more pictures.
Axles came today and what a relief. The length was dead nuts on!
The locking pin slipped in and C-clip ends where slug with no slop.
Started working on my leaf spring brackets. Just laid out some steel and will get to welding tomorrow.
I also fitted the wheels on. Should be good to go but need to set the car on the pavement and see where the tires end up with the fender walls. It looks good thought. Productive evening.
Seeing about getting some adjustable shocks from Competition Engineering or KYB.
Anyone use adjustable shocks that could recommend?
oh. And I guess I'm adding about 30-40 extra pounds to the rear. Wont know final weight until complete.
jpg  IMG_20131212_183118_905.jpg (148.87 KB)
39_52aa9821f1552.jpg 459X816 px
jpg  IMG_20131212_172956_834.jpg (154.70 KB)
39_52aa984657965.jpg 816X459 px
jpg  IMG_20131212_181003_064.jpg (131.39 KB)
39_52aa9855429f2.jpg 816X459 px
jpg  IMG_20131212_182659_592.jpg (157.18 KB)
39_52aa986b177b7.jpg 816X459 px
jpg  IMG_20131212_184518_688.jpg (134.19 KB)
39_52aa9884719fc.jpg 816X459 px
jpg  IMG_20131212_183724_759.jpg (115.08 KB)
39_52aa98ac6e4f4.jpg 459X816 px
Posted on: 2013/12/13 5:21
'73 2 Door Sedan
From Trinidad and tobago
Great!Whats the thing in the diff for?
Posted on: 2013/12/13 7:20
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
That is the pre-load spring for the Ford posi-traction. Similar to an LSD. Clutch plates are located to both side.
I have this same rearend in my Mustang and it definitely works.
Posted on: 2013/12/13 8:03
'73 2 Door Sedan
It is an LSD, which is the generic term. Positraction is a GM trademark.
Posted on: 2013/12/13 8:28
From ATLANTA GEORGIA USA
You still retain the C-Clip system in this 8.8 rear end?
Why noot go with the C clip eliminators just to be safe in that department, sorry i didnt read the whole thread, and awesome built u got here!
Posted on: 2013/12/14 7:57
SR20 Carbed Datsun B310
That is a very good question. Thanks!!
The C clip eliminators is another future project. Right now I'm just trying to get this project done. I'm getting closer.
Last night I tack welded the diff to the my leaf springs. It took a while. Jacking the car up, temp clamping the diff, putting the wheels on, setting back on the garage floor and measuring the tires to the fender wells and the angle of the pumpkin and the backing it back up and doing it all over again. Finally got it within a 1/16 of an inch centered.
The tires are nicley fitted under the car.
Will finish up the welding when I get my drag shocks. Need those before I can build the shock mounts on the leaf spring bracket.
Posted on: 2013/12/14 16:01
'73 2 Door Sedan
