Turbo and Supercharger Myth??
From Sunshine Coast
Hey guys I'm brand new to this forum, I own a Datsun 1000 wagon and I am on the datsun1000 site aswell. I thought i'd just post this up as I did post it on datsun1000 but didn't get many answers. Thanks Dave for replying on there, I am just looking to get heaps of peoples opinions on this. Anyways it went like this!
So I am also reasonably new to cars, most of all my research has been here, online. I have a fair idea on the basics of how engines work and what parts do and all the internals etc etc etc I just lack hands on experience.
Anyways I thought I'd just prepare you with my limitations before I throw this possibly obvious-answered question out there...
Question is: (ok it's not a question...) I have heard people saying that turbocharging is somewhat more efficient over superchargers (Roots, Twin or Cent.) but in regards to where they source their energy to spin.... I've seen in discussions people say that 'Exhaust flow is wasted/free energy, that's why turbochargers use minimal energy to spin.'
And ofcourse the following, 'Superchargers are belt driven thus suck usable (more than turbo) energy from the engines rpm...'
Sorry if this makes no sense, best way I can explain it....
But with a turbo, I would have thought that the energy from the exhaust going through the exhaust turbine side of the turbo is still sucking energy from the engine as it's a restriction of flow... and technically the restriction of flow is equal to how much air is being compressed through the intake side?
So with a supercharger, the same restriction to the engine is how much energy it takes to compress the intake air, plus the little energy to actually free spin the 'turbine' things...?
Is this making sense? I do understand the fact that the turbo needs to spool up and supercharger is instant power (and that it obviously doesn't mean supercharger is better etc) and I understand the differences in power throughout the rpm range.
What I am trying to ask is, isn't the only REAL difference the efficiency of design in both turbo and sc when talking about the source of energy??
Correct me if this isn't even an issue and people don't say these things and that I read their reply wrong??????
Thanks guys, look forward to discussing datto's with you all.
Matt
Posted on: 2013/12/26 10:08
Re: Turbo and Supercharger Myth??
Just twin charge it ( supercharger and turbo) and live with boost through the whole rev range.
Posted on: 2013/12/26 10:20
From Sunshine Coast
I was more so after an answer, I'm not asking which I should use, I know which I will use, it's more a general question for the myth of wasted/free energy from exhaust... Thanks for your input anyways, though I don't think twin charge would be an easy job for someone stating they learned about cars online and still have minimal hands on experience, but still thanks...
Matt
Posted on: 2013/12/26 10:29
Theoretically id belive turbos would be more efficent by design however its based upon the units intended purpose.
Superchargers are typically for low down torque and go where turbos are based on the exhaust and copressor housing sizes.
Small compressor housing low rpm boost but restrictive and generates too much heat larger exhaust housing less restriction but lagier due to rpms needed to get the exhaust gases flowing to spool the impeller.
Either way theres a compromise so theoretically its a waste of effprt working out which one unless every tenth of a second counts racing.
In a road or ocassional track car wont make much difference as road needs torque to get to 100kmh. Any more is a waste by design for law abiding citizens
Posted on: 2013/12/26 10:41
From Sunshine Coast
Cheers again for reply, I understand the difference between the two but, have you heard of anyone saying that turbo is using wasted free energy from the exhaust? Sorry if I sound confusing or I am not asking directly what I really mean, that tends to be my life story, confusing people... But do you understand what I am asking?
Posted on: 2013/12/26 10:46
Yes the turbo converts the wasted energy from the exhsist. Exhaust gas flow to spin the compressor turbine that spins the shaft spining the compressor turbine forcing more compressed air into the motor under boost.
So the more accurate way to describe it would be in a turbo situation, the exhaust gas us used to spin the turbo where in supercharged or na situations it would just fliw out the tail pipe doing nothing.
But its not free power there is always a compromise. Weight heat associated accesories to run what ever desired set up you choose. Piping intercoolers etc etc.
Posted on: 2013/12/26 10:52
From Sunshine Coast
Cool ok see that's what I mean, for example if you had an engine set up with an exhaust going into a turbo, and had that turbo's engine compressing air into 'a slow leak air chamber' at say 5 psi for the heck of an example, the engine would still have to 'push' the turbine blades of the exhaust side in order to compress air on the intake side into that chamber. So this means that the engine has to 'push' and that is a restriction of flow, meaning it wasn't just free energy because the cylinders had to use a bit of energy to 'push' the air out of the combust chamber and through the headers into the exhaust turbine with enough power to compress air on the other side. I just drew up some pictures in paint if no one gets what I mean???
1 sec
Posted on: 2013/12/26 11:11
From Sunshine Coast
See in this picture the engine would have to work to compress that chamber
png  Turbo pictures.png (30.33 KB)
17585_52bc0f777ff2f.png 1280X1024 px
Posted on: 2013/12/26 11:13
From Sunshine Coast
And then as you see in this picture the engine would still have to 'push' (which uses energy, so it's not free wasted energy cause the source of energy comes from the cylinder pushing the air out which that power is originally taken from combustion) the exhaust gas through the turbine to make compression on the other side.
I'm sorry if this is annoying to anyone, I'm just a 20 year old kid trying to get my head around a few things, and this never made sense when people said that it's 'wasted energy', it doesn't seem like it is wasted energy as the source goes back to the combustion for power, obviously...??
Am I missing something??????????????
png  Turbo picture 2.png (29.82 KB)
17585_52bc11f5784d6.png 1280X1024 px
Posted on: 2013/12/26 11:24
Edited by MatthewSturdee on 2013/12/26 11:45:12
From Christchurch NZ
You're looking at it wrong.
It isn't the flowof the exhuast gases that spins the turbo. When an engine expels the spend gases, the combustion event can be only milliseconds ago. The (very hot) gasses which are exiting the engine and passing through the turbo are still expanding. So it is more the residual thermal expansion energy of the gasses which the turbo is recycling, rather than the exhaust gas flow. I refer to this energy as residualas the initial thermal expansion at the point of combustion is what pushes the piston down the bore to make the engine run in the first place.
The turbo is more efficient because it harnesses the otherwise wasted energy. (VS the belt driver blower's parasitic losses to drive)
The difference is that with their being no lag, the supercharger has the scope to generate substantial bottom end torque.
Horsepower sells cars,
TORQUE wins races.
Most folk here know all too well which camp I'm in.
Posted on: 2013/12/26 20:36
Forced Induction!
