Easiest Transmission Question You'll Answer in 2014
Not too shy to talk
From Seattle, WA
Kindly help me locate the Filler plug on my 4-speed transmission. I see a couple "plug-looking" parts and want to get it right. I've reviewed the Tech Wiki and my shop manual (WTH?) and can't find. Thanks!
Posted on: 2014/1/1 15:55
Late-'75 120Y Coupe, '72 Nova 388 Stroker
Re: Easiest Transmission Question You'll Answer in 2014
From Sydney, Australia
the drain is a female square drive plug. the filler is normally a male square drive plug.
Normally half way up the side of the case.
you need an oil hand pump to fill the gearbox.
Posted on: 2014/1/1 21:15
Not an easy question to answer without a photo.
14mm square plug
Left side of gearbox
Number 3 in this diagram
Transmission Case Part Numbers
Posted on: 2014/1/2 3:15
Not too shy to talk
From Seattle, WA
Okay, I'll bite... Why do you think the drain plug is not drawn on the picture? (In F5C56A, it's #27.)
Posted on: 2014/1/2 21:29
From Townsville, Qld
#27 is the speedometer pinion drive, not the drain plug.
Posted on: 2014/1/3 5:37
Not too shy to talk
From Seattle, WA
LittleFireyOne: I'm looking at F5C56A, which I realize is NOT my tranny, but it has a drain plug listed (see 27 08931-44210 PLUG-drain). You are referring to the F4W56A, which IS my tranny and does not have a PLUG-drain listed.
So, my question remains. Anyway, I'm sure I'll get underneath the car tomorrow and see it, but I was just curious why they don't have it listed on the F4W56A, when they do on the F5C56A.
Posted on: 2014/1/3 15:29
