5 speed gearbox
From Leeton NSW
Hey guys I know this has probably been answered so im sorry if it has but Im starting to think its time to upgrade to a 5 speed in my datto now Ive heard that it can be done and with a 5 speed out of another datto and it will bolt up.. now just wondering if someone can tell me if it will be a direct bolt in job and wont need any mods at all to the tailshaft or diff or anything or if I will need to make some mods as from what ive read real quickly some people say it will bolt straight up with no mods while others are disagreeing. thanks Andrew
Posted on: 2014/1/10 14:27
Get in, sit down, shut up and hang on!!!
Re: 5 speed gearbox
All 5-speeds require some mods, mostly minor. See 5-speeds.
Posted on: 2014/1/10 18:11
Re: 5 speed gearbox
From sydney australia
You sometimes need to make space in the transmission tunnel over the clutch fork, usually with a big hammer. You do have to make another gearbox crossmember, as the overdrive 5 speeds have the mount further back on the box. This is usually a U shaped plate that faces forward, so the standard mounts can be used. Or either B-Projects or Pitroad sold a kit to do the same that looked really good. I'm sure that there are photos in the Album & the wiki, showing you what to do. I can remember posting photos myself a few years ago of some I had. The tailshaft is the correct length & size already. You also have problems with the reversing light hitting the gearbox body mounts. I always fitted the gearbox to the engine, then letting the back of the box down enough so you could fit the reversing light. I'd then jack the gearbox up into the car. A few taps with a ballpein hammer to the front of the body mount can help, too. This is on the right hand side, obviously.
Posted on: 2014/1/11 0:04
Re: 5 speed gearbox
From Leeton NSW
Ahhk thanks for the help guys seems like theres abit of work involved in getting one in and I dont have the tools nor the time to muck around unless I can find someone that is selling a gearbox and a fitting kit? Ill send that b projects a Facebook message and see where it leads me thanks for the info guys..Quote:
Posted on: 2014/1/14 4:49
Re: 5 speed gearbox
From Adelaide South Australia
my 5 speed just went straight in A series to A series though.
Posted on: 2014/1/14 6:17
Re: 5 speed gearbox
From Leeton NSW
Ahhhk what series 5 speed was it ?? See I have heard they bolt straight up to but then I get told otherwise mmm but then read reading other threads and from people past experiences and they say they dont...Quote:
Posted on: 2014/1/14 6:44
Re: 5 speed gearbox
Yes, they bolt straight up to the engine. But not to the gearbox crossmember.
Posted on: 2014/1/14 23:16
Re: 5 speed gearbox
Sorry bout that, didn't mean to worry you bout the swap. Getting the box in is a lot easier than some other swaps. You don't have to fit the reversing light switch, or clearance the transmission tunnel. If you can get that gearbox crossmember from BProjects that'd be great, but somebody like Stuart Wilkins at SWMotorsport would probably be able to make you something that'd work & mail it to you. To me a true bolt in is where you don't have to modify anything, like fitting an A15 into a 120Y or Sunny. Fitting the 5 speed is very easy, but there is some modification needed. The number for SWR is 02-4577-2400 or www.swmotorsport.com.au.
Posted on: 2014/1/14 23:21
Re: 5 speed gearbox
There are 4 different Datsun 5-speeds that bolt up to A-series engines. Each is a little different in how they are fitted. See http://datsun1200.com/modules/mediawi ... -speeds#Swap_Instructions
Posted on: 2014/1/14 23:55
Re: 5 speed gearbox
From Launceston, Tasmania
Is the A series 5-speed going into a 1200?
Posted on: 2014/1/15 0:35
