Choose offset
From Lisbon
Hi
Sorry for the insistance in this subject
I Have no ideia, which is the best offset for front and rear whells Datsun 1200 using 13*6 and 175/60 Tyres
Some people says +23mm
others +16, +15 others +5
I think is 0mm
Really i dont know how they calculate them?
I dont know if they use spacers or not.
I only want the best offset without spacers, fitting the car with security and looks good
I dont like see a car with wheels to inside the body or outside the body.
Many thanks
Miguel
Posted on: 2014/1/9 21:17
Re: Choose offset
O que o TROFÉU usar? Parece que Portugal poderia saber melhor sobre esses assuntos.
Posted on: 2014/1/9 21:41
Re: Choose offset
From Lisbon
Thank you for your quicly reply
Posted on: 2014/1/9 21:52
Re: Choose offset
From Lisbon
Hi
I take the front measures chassis offset of my Datsun 1200 sedan 2 door sedan, and i have:
face measure 60mm
back measure 109mm
And you have:
face measure 109mm
back measure 89 mm
It is posible.
With measurements of my car i can use 13*6 wheels 175/60 tyres offset +23 mm
6"=152.40
centerline 152.40/2=76.20
76.2+23=99.20
76.20-23=53.20
face measure 60-53.20=6.80 clearance
back measure 109-76.20=32.80 clearance
I thinking wright?
Many thanks
Luis
Posted on: 2014/1/14 17:28
Re: Choose offset
From Brisbane, Australia
You're on the right track but a 6" wheel will measure 7" total width. This is because wheel sizes are taken from inside the bead seat, not overall width. Like this demonstrates:
Posted on: 2014/1/14 22:39
Re: Choose offset
Also consider the Tyre. A 175 tire is wider than 6". The Tyre us ire likely to rub than the wheel
Posted on: 2014/1/14 23:06
Re: Choose offset
From Lisbon
Hi
Thank you for your replies
13*6 wheell measures 7" total with
7"=177.80mm
Centerline=88.90
offset +8mm
88.90+8=96.90 Back 89mm Dont Fit
88.90-8=80.90 Face 109mm Fit
Even i choose 0 offset dont fit
I need to use a diferente size of wheel?
Many thanks
Luis
Posted on: 2014/1/15 17:01
Re: Choose offset
From Lisbon
13*6 7"total with negative offset
13*5 6" total and configure a offset
Im correct
Im pretending to buy them online and i dont get a bad suprisse!!
Many thanks on advance
Luis
Posted on: 2014/1/15 17:19
Re: Choose offset
A 5" wheel offset 0 rubs on the inside of the fender. Many people run this as the fenders can be rolled, pulled or flared.
Posted on: 2014/1/15 20:23
Re: Choose offset
From Lisbon
Hi
13*6 ET +8 has 97mm Backspace
ET +16 has 105mm Backspace
ET +28 has 117mm Backspace
At the moment i cant measure the front chassis offset of my car.
But is official that the back measure has only 89mm?
I ve 12" wheels with bacspace 96mm, 13" whells has 97mm im confused, the only thing to fit them was cutting a piece of caliper height
Many thanks on advance?
Luis
Posted on: 2014/1/15 21:24
