stronger clutch for a 1200
From oregon in the usa
Thought I'd better ask: Can anyone suggest a suitable presure plate which will hold more torque than the original 1200 one?
Posted on: 2014/1/20 7:18
Re: stronger clutch for a 1200
From Christchurch NZ
My local clutch guy has a custom pressure plate, made with double diaphram springs. Only want's $140 for it.
Another option is to have the flywheel remachined to take a 200mm hd LD20 pressure plate, and run a clutch disc from a fwd sr20 primera.
Posted on: 2014/1/20 8:11
Forced Induction!
First ensure the clutch is adjusted properly. If the is no play, it will slip.
A high RPM engine will usually have less
torque, so not hard on the clutch unless you are applying s lot of throttle while letting up on the clutch pedal.
Posted on: 2014/1/20 8:36
Posted on: 2014/1/20 8:40
Exedy makes a few types, from you std replacement up to a heavy duty ceramic one from memory...
think prices ranged from around $120-$500
Posted on: 2014/1/20 8:54
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
