(1) 2 3 »
cheap strong diff for 1200 ute project
Quite a regular
Hey guys van you give me some suggestions for buying a diff for my 1200 project. It only needs to be able to cope with about 400hp out of a 13b rotor.
Just need something easy to work with and strong and cheap. Waslooking at vl turbo diffs but tthey are dear
It will be shortened and have a nee 4.11 centre put in later.
Anyone throw me some ideas?
Tom
Posted on: 2014/2/5 7:01
Re: cheap strong diff for 1200 ute project
400 HP @ 9000 rpm needs a diff only half as strong ad with 400 HP @ 4500 rpm. I think the stick ute diff is strong enough for high-rpm (low torque) 400 HP.
Or will you be making HP at a lower rpm e.g. a turbo motor?
Posted on: 2014/2/5 7:33
Quite a regular
So basically any manual Ute diff ay?
I should prolly go with a hilux diff then due to parts being so readily available.
Any year models better than others or are they all the same kettle of fish? Haha
Posted on: 2014/2/5 7:37
Quite a regular
And sorry forgot to reply to this.
I'm just going to be running a NA peripheral port 13b rotor with 51mm idas and a s5 5 speed.
Nothing crazy. Just sounds nice and is a bit of fun
Posted on: 2014/2/5 7:39
Any 1200 ute diff can handle sustained 225 ft lbs of torque.
Posted on: 2014/2/5 7:58
Quite a regular
Stud patterns are crap on the standard diff. Shorten a pair of 5 x114.3 axles?
Posted on: 2014/2/5 8:02
Nothing wrong with the stud pattern. S13 and skylines used it.
Posted on: 2014/2/5 8:20
Quite a regular
My issue is the wheels I want to run on her don't come in that stud pattern. I need a 5 stud
Posted on: 2014/2/5 8:39
From penrith,sydney,aus
Hilux is 5 stud, just needs shortening
Posted on: 2014/2/5 9:23
2 door 1200 sedan project l20b stroker
From Canberra
borgwarner 9 bolt lsd 4.11 ratio..
thats what i got don't cost much at all find them anyway to get shortened and then tailshaft shortened and rear uni changed cost me $1200
most expensive thing was the R32 disk setup and because i changed to billet axels lol
Posted on: 2014/2/5 10:11
(1) 2 3 »
