Hilux are a top choice but once you shorten them,
leaf spring mounts to suit right stud pattern mods
is 2000+aud depending on purchase price and place
doing the work for you or doing it yourself.
Bluey H190 un-shortened + Jap H190 LSD is better
as Rotary peeps bust the strong 177.5mm & inch
mazda rotary diffs and go for hilux or 9 inch.
Rotary diffs with 4.875 centres are stronger than H165
metallurgy/quality is Nissan-like but not up to turbo 13b
torque or abuse for long before they give up the ghost.
I can get the LSD units to fit the H190 bluebird which has
correct stud pattern 4 x 114.3mm & bluey diffs are cheap
and 1450mm vs 1305mm for H165 so no shortening required
if you have the right offset wheels 40-45mm is nothing.
So un-shortened bluey diff $120 at most wreckers like pickapart
and LSD unit 950 from Japan & modded mounts around 1300 total.
Alloy carrier option also available for H190 for lightweight.
H145 5.71 ~100 lb. ft.
H150 5.91 ~125 lb. ft.
H165 6.50 ~225 lb. ft.
H190 7.49 ~285 lb. ft.
R200 7.88 ~300 lb. ft.
