(1) 2 3 »
alternator overcharging
From vic
So i have bought a new external voltage regulator for my 120y and replaced the brushes in my alternator
the problem i am having is that when the ignition is turned on the charge light does not turn on
then when you start the car the charge light turns on a will keep getting brighter as the rpm increase my multimeter shows close to 16volts
and when i connect the external regulator the engine seems to sound loaded up and when you disconnect it the rpm goes up abit
this makes me think its a voltage regulator problem but its brand new
any ideas?
Thanks
Posted on: 2014/2/10 10:06
Re: alternator overcharging
From Stone Age somewhere in U.S.A.
Normal charge voltage should be 13.8 to 14.8 volts, but if the battery is low it could possibly go that high. Another thing to look at is if the electrical connectors are not clean, as in bright and shinny, this could cause high resistance in the circuit and cause the regulator to raise the voltage to overcome it.
Personally I would start by cleaning all the electrical connections.
Posted on: 2014/2/10 15:36
Yes, both the light and the voltage are controlled by the VR. I'd say it is bad.
Posted on: 2014/2/10 17:00
From Trinidad and tobago
Proberly a bad voltage regular,had that problem before.try putting on the lights then start car or start the car ten put on the lights.
Posted on: 2014/2/10 20:46
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
From vic
this is the voltage regulator i have bought it seems to be the right one
http://cgi.ebay.com.au/ws/eBayISAPI.d ... geName=ADME:X:RTQ:AU:1123
Posted on: 2014/2/10 21:14
seems to be working?
Best way to test out if its really working,Start the car,Then remove the negative battery pole while the car is still running,If the car shuts off immediately then its the Voltage regulator .If it doesn't cut off the regulator is good.
Posted on: 2014/2/12 19:59
Street Sleeper!
That test won't tell you if the regulator is overcharging. So use a voltmeter.
Posted on: 2014/2/12 20:55
Test is to verify if the voltage regulator is working.How could u test it if its not working
Posted on: 2014/2/13 0:22
Street Sleeper!
The voltage regulator can be working, yet with low voltage or high voltage it will ruin the battery. Testing for correct voltage is the best test. 13.5-15 volts is good. See Voltage Regulator for more details.
Posted on: 2014/2/13 1:23
Darrenwilson. You have committed a very bad sin, you have spelt Datsun wrong in your avatar picture!
Posted on: 2014/2/13 1:46
(1) 2 3 »
